If it feels right to slow down, then slow down. Stay inside your comfort zone.
Couple of other thoughts. As mentioned, be sure to consciously look well ahead in the curve. Also, (traffic permitting), try slowing down before the curve, then accelerating smoothly through it.
+1 it will come the more you get under your belt. Practice practice practice. Soon enough you will look back and wonder why you even struggled with it. Cautious is not always bad as long as you don’t over do it. Stay safe.
You are not the first and you can easily work through this.
As mentioned in several posts practice the counter steer.
You have to push forward with your left hand to go left. The opposite to go right. This is critical and needs to be automatic or you will find yourself in trouble one day and not make a curve. If this does not make sense, then try riding with only one hand and you will see that to turn left you have to PULL with your right hand?
Good luck and don't ride faster than your skill level. I would stay away from poker runs and group rides until you get more experience and get this worked out.
Bought my first bike in 2017, been learning to ride it since.....I still have to slow down on a left hand curve. Why?! It’s driving me nuts!
Not much info here in your orig post, not going to read every response, all that said, you might want to find a smaller bike and practice your turning, my years of riding everything from bicycles to Harley's has made me completely comfortable, if you skipped straight to a Harley, you may have missed the learning curve or curves :-)
