Hey guys, yes, I have a K&N, it came red, but it's easily removed when cleaned and the filter looks gray. I then oil it with blue oil instead of red. Drag Specialties filter oil, blue
Originally Posted by seniorsuperglideE8
Nice blue bike there bluesrider.
Thanks!
Not sure what oil you are using but this is my third bike with a open filter and everyone is red after being cleaned and recoiled. I also do it every 5,000 miles are right before a long road trip
After farther inspection the Air filter is a Harley dry element filter. So that explains the color thing thanks for the input. Do you guys think that a adjustment in the ECM will need to be change for just putting on a screaming eagle cleaner The bike is a stock 103 2016. Tech's at the Harley shop says that the ECM should be able to adjust for the small change that this will make.Only changes from stock is a set of factory stock CVO slip-ons. Any input will be welcomed. thanks
If you already have slip-ons, and now you do a higher flow intake, you need to have the tuning done. Otherwise the bike will run lean/hot. Personally I'd add a tuner (like a PowerVision) instead of having the dealer flash the ECM.
I posted a similar thread earlier this year and most of the replies were basically: the guy who told you that is on crack.
Any K&N filter exposed to sunlight will turn grey. Mine does.
This reply wins the "Has Nothing To Do With The Original Poster's Question" award. Yay!
Keith, I don't remember you being a butthole in other threads, so I'll overlook it just this once. If you look at post #13 you'll see the question I replied to.
"Yay!" back to ya.
The oil grabs the fine stuff since if you look thru the filter with a light on the other side, you will realize that anything smaller then a match head needs something to catch on as it bounces thru the medium. Hence the oil film.
Good for your Harley if you use it primarily for a drag strip and you want that last HP out at rev-limiter RPM and figure you will re-ring it after a few dozen runs.
If you use it on the street and want an engine to last, don't really care for the Hover Vac noise, leave it stock.
"Yay!" back to ya.
I just like to cause trouble. Sorry, you're right, didn't notice that question. But its your fault for not quoting the post. :-P
