Ummm... Not sure what a pic will do for stuff that’s inside my tires? I’m gonna need one of those cameras doctors stick up your butt maybe? LOL
Oh. Ok mate. Did not realize that. So sorry. I will need to go re-read this thread from the beginning. Thanks and go back to what you were doing.
Originally Posted by hvacgaspiping
So, do you want him to show you photos of the stuff spread out around the inside of his tire after he has to remove it again just to take a photo??? That`s the only way you`re gonna get to see anything.
No, no. That is ok. Did not realize it. Wow. Thanks tho. "At ease soldier and go back to what you were doing with Bonnie. (Or Jonathan.) 'doh!"
I've been using Ride-on for years. I change my own tires and use it for puncture protection and balancing. AAAAND it also works with a puncture in a tube, which I run. Keep in mind, it only seals a puncture on the center section of the tire, if it's toward the edge or side, no worky.
I just put the ride on into the tires of both of my cycles. Haven't tried them yet. I was going to run the cycles a bit and see how it works before pulling the wheel weights off or can I just leave them on?
