1980 flh
Old Apr 28, 2019 | 09:16 AM
campratt's Avatar
campratt
Stage III
Default 1980 flh
When changing the wire from the points to the coil what gauge wire should I use and is there supposed to be a rubber grommet under the points cover where the wire goes through
Old Apr 28, 2019 | 10:14 AM
14GuineaPig's Avatar
14GuineaPig
I can't find any grommet shown in the parts diagram. A 1980 FLH should be running electronic ignition stock from the factory. I don't see the wire gauge listed but here's a listing for the points to coil wire …. https://www.jpcycles.com/product/300...-breaker-wires
Old Apr 28, 2019 | 10:17 AM
byersmtrco's Avatar
byersmtrco
I had very good luck with the Dyna-S in
my Shovelheads
Old Apr 28, 2019 | 11:34 AM
hardheaded's Avatar
hardheaded
That first gen. electronic ignition was junk and known for leaving you stranded. Everyone swapped them out for points back then. The wire size is 16-14 and the blue crimp connections. Either will work.
Jolly_Roger
18
Jun 17, 2019 06:54 PM
shizzomynizzo
Electrical/Lighting/Alarm
Aug 21, 2014 07:22 PM
MyClassic09
May 24, 2013 08:50 AM
Just Blaze
Jun 2, 2012 12:02 PM
georgedexter
Oct 21, 2007 06:38 PM
