Leaky valve stem
Old May 2, 2019 | 05:04 PM
4MercyMan's Avatar
4MercyMan
Default Leaky valve stem
Here we go. I bought tires online and had them mounted and balance at the local Honda dealership cause the owner is a friend of mine. They did not put a new valve stem in the tubeless rear tire which is mounted on a solid rim. The tire is now losing about 2lbs of air per day around the valve stem. Is there a way to seal this without removing the tire from the bike? Can the nut on the stem be removed and a gasket be placed under the nut? Thanks Ride safe.
Old May 2, 2019 | 05:11 PM
adm's Avatar
adm
No. Not really. You'll need to take the wheel back and have a new valve put in. You can never really seal a high to low pressure gradient from the outside.
Old May 2, 2019 | 05:30 PM
monkeyboy22's Avatar
monkeyboy22
If the tire is wide enough and the sidewall is flexible enough, you could install a new valve stem in the wheel without removing the tire.
Old May 3, 2019 | 07:40 AM
RHPAW's Avatar
RHPAW
You can try changing the Schrader valve yourself for about 20 cents.
Any hardware store.
Old May 3, 2019 | 08:08 AM
Johnnypop's Avatar
Johnnypop
If your lucky the inside of the valve stem my need to be tightened. Also get a bowl with soapy water and use a brush to go around the bead and valve stem to confirm the leak.
Old May 3, 2019 | 08:24 AM
GBHH's Avatar
GBHH
Good practice to replace w tire, Maybe became dry.
4MercyMan
Wheels/Tires
May 2, 2019 11:53 PM
Spartanden
Jul 6, 2016 04:22 PM
EasTexUltra12
Apr 8, 2014 05:11 PM
tmac00333
Jul 29, 2013 10:43 AM
drharley
Aug 9, 2011 10:50 PM
