Changing handlebars
Old Jul 11, 2019 | 03:27 AM
Lamicus's Avatar
Lamicus
2nd Gear
Default Changing handlebars
Hi, I'm thinking of changing to western or beach bars on my 2013 Fat boy and wondering if anyone has done it and could enlighten me as to whether the wires and cables need to be lengthened and how to go about it?
Old Jul 11, 2019 | 06:31 AM
Bubba Zanetti's Avatar
Bubba Zanetti
How much longer are the bars you currently have. Generally speaking you can go 3 or 4 inches without any problem at all, maybe another inch or two if you re-route the cables. Anything much more than that and you'll be changing cables and brake lines.
Old Jul 11, 2019 | 11:49 AM
Lamicus's Avatar
Lamicus
2nd Gear
I'm not sure of the exact length of the new bars, I figured there might be some one on here that has done the exact same change and can let me know what was involved.
Old Jul 11, 2019 | 12:09 PM
BuckKnuckle's Avatar
BuckKnuckle
It can depend on several factors. I just changed out my stock bars on my 08 FXDL and put on Dominators.
The hand grip heights weren't that much different, but the angles were completely different, requiring
more cable length than one would think.
I took a string and traced along each cable and measured its length with the current bars from a fixed point on the
bars (right above the triple tree).. Then I rigged up the new ones (just taped them on) and used the string, starting
from the same point, to see where things would end up. I ended up needing +4's for everything, even though the
grips were only a couple inches higher than stock.
Old Jul 11, 2019 | 12:21 PM
Jersey Drew's Avatar
Jersey Drew
probably get better answers if you post in the softail forum
Old Jul 11, 2019 | 12:24 PM
Cygnusx51's Avatar
Cygnusx51
If you don’t know the exact length of the bars, how would anyone else know if they’ve already done the exact same change?
Get the new bars, measure the difference, order the extensions and new cables if you need to.
Old Jul 11, 2019 | 01:51 PM
AJSHOVEL's Avatar
AJSHOVEL
Figuring out whether you need longer wiring and cables is the same for all bikes.
Old Jul 11, 2019 | 05:50 PM
Lamicus's Avatar
Lamicus
2nd Gear
Because western bars are all the same length.
Old Jul 11, 2019 | 06:00 PM
Lamicus's Avatar
Lamicus
2nd Gear
That was what we did before HD forums come along with a plethora of information on hand. I'm trying to work out the cost of this before I start and whether or not it'll still appeal.
Old Jul 12, 2019 | 10:53 AM
AJSHOVEL's Avatar
AJSHOVEL
Are they?
My advise would be to get the bars you want and are more comfortable for you, and do what it takes to make them work. If they require lengthening of wiring and longer cables, so be it. It's pretty easy to do. While you're at it, either buy your bars pre-drilled or drill them yourself and run the wiring internally. Makes a nice clean looking job.
