So, you've replaced the internals so that some sort of 12V lamp will fit into the flashlights? Once that, or something is done to allow 12v to operate the flashlights, it is simple. You already have a wire that is hot when the brakes are applied, Splice another wire to that one. Run one to one of the flash lights, and the other wire to the other light. Do the same for the ground wire.
It becomes a "whole 'nother story" if you're not replacing the flash light guts, or trying to use them as combination tail and brake lights.
