The Owner's Manual has this information clearly stated in the "Specifications" section: 505 lbs. This link should show you an owner's manual (HERE).
You can figure it out by using the sticker on the side on the frame. GVWR - Vehicle Weight = carrying capacity.
GVWR is the maximum weight of EVERYTHING (bike, accessories, cargo, riding gear, passenger and rider). Subtract the vehicle weight from GVWR to figure out carrying capacity.
At this link (HERE), it has GVWR for a 2019 Road Glide Special as 1360 lbs. and vehicle weight as 855 lbs. Therefore, 1360 lbs. - 855 lbs. = 505 lbs.
Add up the vehicle weight, cargo, occupant weight and subtract that from your tires weight capacity. This is how they determine what a vehicle can carry. They will never exceed the tire weight limit.
I checked the same question for sportsters.
It is quite curious that all XLs have the same GVWR of 454 kg (1000 lbs). So lighter and smaller models with less features and even less engine have more maximum allowed load.
First i checked XL1200T which i want to buy, and it has only 183 kg load allowed, almost the same as my lighter 650cc Pegaso, which has 180 kg allowed.
Other sportsters, for example:
XL1200X - 449 lbs, 204 kg.XL1200V - 441 lbs, 200 kg.
