Primary cover bolts
Old Sep 21, 2019 | 08:06 AM
lowriderr9's Avatar
lowriderr9
I didn't see any kind of locker on the bolt. I have several types of soakers and I will try that. The threads on the bolt were shiny and looked good. It has been s while since the primary has been off. Like you said the bolt could have de eloped some corrosion. I do have a new bolt set comming. I only have one type of anti sieze. Wasn't sure if there was a specific one for this.
Old Sep 21, 2019 | 09:38 AM
Zerk's Avatar
Zerk
Originally Posted by Spartanden
what normally happens is a galvanic reaction between the steel bolt and the aluminum case. I would consider replacing all the bolts (a fastener supply house or industrial supply store are good sources) with stainless steel bolts. I would take one of the "good" old bolts and run them into every hole to make sure the go in and out freely. Consider a dab of anti-seize when installing new bolts. And a quick check on the torque/snugness of these should be part of your service routine.
If you use stainless bolts make sure to use anti seize, and reduce tq. When manuals in values when using loctite, probably ok, since both are lubes. I don't recall loctite being used though. I got one off right now and will follow manual when going back on.
Old Sep 21, 2019 | 09:56 AM
Uncle Larry's Avatar
Uncle Larry
Originally Posted by lowriderr9
I would chase the threads but you can't get to them. It is the long bolt that goes through the inner primary. I would have to pull the primary which I am trying to avoid.
I am trying to find out about anti sieze. I think there is more than one kind. For different types of metal. Any information appreciated.
Do not use a tap ... as suggested use a thread chaser for peace of mind ... chasers clean the threads as opposed to a tap ( actually ) cutting material ... As for anti seize, be sure that you use it in a hermetically sealed and controlled environment being sure strip naked naked ( no pictures required ) and burn all clothing before entering the house ... That stuff gets everywhere :<(
Old Sep 21, 2019 | 09:58 AM
Uncle Larry
https://www.google.com/search?ei=Szq...4dUDCAs&uact=5
Old Sep 21, 2019 | 10:36 AM
glasspilot's Avatar
glasspilot
Go buy a long bolt with the same threads. Then cut tiny grooves. You have now made yourself your own thread chaser. Use some oil on it and run it in and out a few times. Now the real bolt will go in nice and smooth.
Old Sep 21, 2019 | 12:45 PM
RK4ME's Avatar
RK4ME
I wouldn't try to "cut" anything out of aluminum threads or chase them unless they were too crudded up thread a bolt into. I'd sooner clean them with a .17 cal nylon bore brush and penetrating oil, maybe chucked into a drill motor.
I never use anti seize on fasteners unless the manufacturers instruction manual calls for it.
Old Sep 21, 2019 | 01:49 PM
Zerk's Avatar
Zerk
I love anti seize, I put the **** on everything. Though I wouldn't here, unless couldn't get it to loosen up. I use on derby and inspection cover.
Old Sep 21, 2019 | 07:17 PM
Down South's Avatar
Down South
I just pulled the primary cover bolts on my Ultra for the first time about two weeks ago. First thing that I noticed is the threads were dry. When I reinstalled the bolts, I used a bit of grease on the threads to help keep them from seizing in the future.
Old Sep 21, 2019 | 08:07 PM
lowriderr9's Avatar
lowriderr9
Some good ideas. I really can't understand why it was so hard to come out. I can't hardly believe it would be cross threaded but I don't know. Like I said the bolt look good. No aluminum on the threads. Other than being hot from working it back and forth it looked fine to me.
I have a .17 caliber rifle. Can't remember what kind of brush it has. Would it hurt if I put a little oil or grease on the bolt and try it.
Old Sep 21, 2019 | 08:41 PM
Down South's Avatar
Down South
I'd try running it in and out a couple times with some grease on the bolt. If you get to a tight spot, back it back out. Then I'd get a tap and chase the threads.
