Yeah, that's pretty normal. You can start it in neutral, but it's going to "clunk" when you put it in gear, so I guess it's a coin flip. Some will say it's hard on the starter when you start it in gear with the clutch pulled in.
Edit - Never mind on the "clunk". I hear M8s don't clunk when you put them in gear.
When I complained about this happening when I first bought my '18 Heritage, almost all the responces were scoldings. I was told over and over that I should only start in neutral.
Now this also happens on my '19 SGS. On both bikes it only occurs when the bikes are cold. After warmed up, there is very little, if any, lurch when starting in gear.
I try to remember to make sure I'm in neutral before starting when the bikes are cold but what they say about good intentions...so if I forget I just live with it.
You're not putting much more load on the starter when starting in gear and clutch pulled in vs starting in neutral. The effort to overcome the clutch drag is small compared to what it takes to turn the engine over.
