Running rough
Old Oct 7, 2019 | 02:06 PM
darrelld1967's Avatar
darrelld1967
3rd Gear
Default Running rough
I have a 2000 softail standard with Vance and Hines straight pipes the other day I started to break up idols perfect went to drive it out the driveway it started to bug and joke if I keep pushing it it runs OK but then when I stop at a light and start to go again it bogs out and keeps back fire
Old Oct 8, 2019 | 06:53 AM
Bubba Zanetti's Avatar
Bubba Zanetti
Fuel injected or carb? If fuel injected check the fuel line inside the gas tank for pinholes or a clogged filter. Might also take a look at the vehicle speed sensor.
Old Oct 8, 2019 | 08:19 AM
darrelld1967
3rd Gear
No 2000 only comes carbureted
Old Oct 8, 2019 | 09:35 AM
dlema25247's Avatar
dlema25247
2nd Gear
I had a similar issue with my 95 Ultra Classic EFI. Replaced the Crank Sensor and it ran perfect again.
Good luck!!
David
Old Oct 8, 2019 | 09:40 AM
packmen21's Avatar
packmen21
Good luck!!
David
+1
Old Oct 8, 2019 | 10:08 AM
Riffraff123's Avatar
Riffraff123
It was actually an option for fuel injection on 2000 FLSTC, mine is carbed tho. To start I'd check your ignition switch connections under the speedo for corrosion, check plug condition for rich or lean conditions, intake manifold/carb boot for leaks and plug/coil wires for condition and clean carb if it hasn't been done already. It's very tough to get a good tune on VH straight pipes...ask me how I know.
Good luck!
Old Oct 8, 2019 | 09:54 PM
sechracer's Avatar
sechracer
K.I.S.S. check your plugs......
misfitJason
Softail Parts
Jan 23, 2017 07:29 PM
Chad263
Dyna Parts
Nov 9, 2016 06:27 PM
jneubig
Softail Parts
Aug 21, 2010 12:24 PM
snooper0069
May 24, 2010 09:32 AM
sheriff fatman
Feb 7, 2006 01:14 PM
