Boom Audio Speaker not blown but no sound
Old Oct 15, 2019 | 04:00 PM
starrett7's Avatar
starrett7
Stage IV
Default Boom Audio Speaker not blown but no sound
I have a 2014 CVO limited with the Boom Audio system. Three of the four speakers work. I took the front (throttle side) speaker out of the Batwing and tested it and it works. I checked and cleaned the connectors, still no sound. Is each speaker independently fused? Next steps? Thoughts?
Old Oct 15, 2019 | 05:45 PM
nobodyknowsme's Avatar
nobodyknowsme
Sounds like a break in the wire, likely at the connector? Just a long distance guess.
Old Oct 15, 2019 | 05:50 PM
Dsm Limited's Avatar
Dsm Limited
Did you swap left for right and see if the problem follows the speaker? If the problem stays on the right side, a probable plug or wire issue. You can also check for speaker output voltage. A digital multi meter set on AC voltage will tell you if the amp has output.
Old Oct 15, 2019 | 07:00 PM
FatboysFatboy96's Avatar
FatboysFatboy96
Could be the amp. Had a similar issue and it was that channel on the amp.
Old Oct 15, 2019 | 07:17 PM
CaffeineBuzz's Avatar
CaffeineBuzz
Oh darn...time to upgrade!!!!
Old Oct 15, 2019 | 07:23 PM
DanHappy's Avatar
DanHappy
Dumb but really easy check. Check to see if the fader was not pushed to the other side....
dub976
Audio Systems
Apr 13, 2019 08:08 AM
Stash
Apr 5, 2015 06:30 AM
omgtkk
Apr 5, 2011 08:12 PM
abrown2669
Apr 1, 2011 04:08 PM
bobros
Dec 5, 2008 08:24 PM
