Please help
Old Feb 17, 2020 | 07:19 PM
Johnboy1977's Avatar
Johnboy1977
1st Gear
Default Please help
I had to change the inner shift lever on my 88 ultra classic. Had to take inner and outer primary off as well as clutch basket, Well since getting it all back together I have noticed that my clutch has no resistance on it and I run out of adjustment before it starts moving the lever. Please help me...
Old Feb 17, 2020 | 07:44 PM
Tommy C's Avatar
Tommy C
The ***** probably fall out of the ramps that actuate the push rod for the clutch. Time to consult the Factory Service Manual.
Old Feb 17, 2020 | 08:24 PM
Johnboy1977
1st Gear
Default ???
Do what??
Old Feb 17, 2020 | 08:40 PM
nevil's Avatar
nevil
It was a pretty straightforward suggestion. Check the clutch actuator mechanism on the left side of the bike where the cable goes into. Should be a piece of cake compared to pulling the inner and outer primary covers.
Old Feb 17, 2020 | 08:44 PM
Tommy C's Avatar
Tommy C
Originally Posted by nevil
It was a pretty straightforward suggestion. Check the clutch actuator mechanism on the right side of the bike where the cable goes into. Should be a piece of cake compared to pulling the inner and outer primary covers.
Fixed it for you.
Old Feb 18, 2020 | 11:48 AM
DanHappy's Avatar
DanHappy
Check the manual that shows how to adjust and replace the clutch cable. It will explain that. Real easy to do.
Old Feb 18, 2020 | 04:05 PM
TheMurf's Avatar
TheMurf
Default Help
The first year for the Ultra Classic was 1989.. l believe your bike is a Electra Glide..
Old Feb 19, 2020 | 09:29 AM
Johnboy1977
1st Gear
thanks for everyone's help. I got it fixed ...
Old Feb 19, 2020 | 09:34 AM
nevil's Avatar
nevil
Great! Please share with us what you did to fix it. This could help others in the future.
Old Feb 19, 2020 | 11:45 AM
DanHappy's Avatar
DanHappy
Yea! Even if it something simple or stupid. We deserve that at least!!!
