How many Amps do our bike charge at ?
Old Apr 3, 2020 | 02:54 PM
Iron lHorse's Avatar
Iron lHorse
All charging systems are built for volts and amps . The upper charger is 12 / 1.25 and the lower charger is 12/2 or 12/10.
So when our bikes are running what does the system put out . 12/ ?
Old Apr 3, 2020 | 06:20 PM
Uncle Larry's Avatar
Uncle Larry
Originally Posted by RHPAW
Eleventy-two.
You forgot to carry the one
Old Apr 3, 2020 | 06:32 PM
RANGER73's Avatar
RANGER73
14.5 volts at 1100 RPM min. But it puts out volts, not amps.
The stators vary in amps by years my 94 is 32 amps.
It's sized by the load of the bike, lights and acc.'s
The stators job is to keep up with the load draw on the battery, to much draw kills the stator.
Like if the battery starts to fail the stator tries to supplement the difference and burns itself out.
I'm sure you've heard that a bad battery took out a stator, this is why.
Old Apr 3, 2020 | 06:33 PM
RANGER73's Avatar
RANGER73
120/121,230/240 what's a few volts?
Old Apr 3, 2020 | 08:28 PM
Bone Doc's Avatar
Bone Doc
I thought watts a few volts x a few amps. I could be wrong.
Old Apr 3, 2020 | 08:59 PM
RANGER73's Avatar
RANGER73
Well he wants to know amps so it's volts/watts.
Hope this helps.
Old Apr 3, 2020 | 09:18 PM
Bone Doc's Avatar
Bone Doc
Hope this helps.
Actually, my comment was a play on words. You said WHAT'S a few volts and I said WATTS is a few volts x (times) a few amps.. It had nothing to do with the OP.
Also, I thought amps would be watts/volts ???
Old Apr 3, 2020 | 09:49 PM
T^2's Avatar
T^2
Don't know what you are asking...
When the bike is running - it's not 12/?.
The system is voltage regulated - in the range of ~ 13.5V to 14.5V. Current is dependent on the load at any given time.
Old Apr 3, 2020 | 09:53 PM
Bass Player's Avatar
Bass Player
Originally Posted by T^2
Come on man... Everybody knows that the answer to everything is 42.
C'mon, that's tire pressure.
Old Apr 3, 2020 | 10:16 PM
Ride my Seesaw's Avatar
Ride my Seesaw
What is the current rating on the bike’s main fuse? Subtract roughly 20 percent of that and this will be the MAXIMUM amount of peak current (amps) that your bike will draw at any given instant, including the battery’s charging current. Your average running or operating current will be much less depending on the accessories turned on. Your absolute maximum normal current draw will be when you hit the starter button, most electrical systems will disconnect momentarily to allow all the Battery’s available current to turn the starter and ignition. After the bike starts everything else will power up and your battery will pull varying amounts of current as it recharges itself from that initial deep starter current depletion.
