Where is my Engine Made?
Old Aug 26, 2020 | 04:17 PM
I Like Pie's Avatar
I Like Pie
I was on the factory motor tour last summer. It is a huge plant that uses LOTS of robots and they are constantly adding more.
Old Aug 26, 2020 | 04:22 PM
Keithhu's Avatar
Keithhu
Where are the robots made?
Old Aug 26, 2020 | 04:29 PM
xnihilo's Avatar
xnihilo
Originally Posted by Keithhu
Right. Very compartmentalized religion, I get it.
Do you?
Old Aug 26, 2020 | 04:41 PM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
Think they talk to each other in Chinese?
Old Aug 26, 2020 | 04:58 PM
skratch's Avatar
skratch
Originally Posted by xnihilo
So what is your observation? Manufacturing or just assembly?
it's really hard to say. it isn't like they show you areas with big smelting pots where they pour liquid metal into molds....
but you do get to see where they put all the pieces together, and the engine run on a 'virtual' dyno. they explain how in the old days, every engine would be run after assembly. but nowadays, they have all these lines go to it where they can run it and see all kinds of diagnostic info on it. it's pretty cool to see.
Old Aug 26, 2020 | 05:36 PM
ve9aa's Avatar
ve9aa
I am a couple thousands of miles away, but have been on the factory tour a couple times. (once in York PA, bike assembly and paint) and twice in Milwaukee Wi, milled and assembled and at that time, rebuilding of engines.
I did not notice any packages from Asia when at either location. Milling machines, lathes, robots & good ol' Americans putting metal together.
Old Aug 26, 2020 | 05:37 PM
Mattbastard's Avatar
Mattbastard
Originally Posted by todd-67
I am not too sure about that. I am reasonably certain that the engine parts are made in North America I am not convinced that they are all made in america. Aluminum casting and chrome plating are not EPA friendly. Most of harley chrome used to be done in canada not sure anymore where it's done. More than likely the castings are as well. Some of this stuff is just to costly to meet the EPA regs.
Exactly! "Made" in America is ambiguous. Most things now a days are Assembled in America with foreign sourced materials.
The ultimate question is where do you define whether or not something is made vs. assembled in America? For instance, the steel Harley uses for their frames, where's the foundry that mined the iron ore for that? Same with the aluminum for the entire engine and transmission casings. A lot of manufacturing processes are not EPA friendly and get outsourced to China.
I'm sure there was a time when Harley used to actually cast their own heads, cylinders, and crankcases. I'd speculate that time is long gone.
Old Aug 26, 2020 | 05:42 PM
TriGeezer's Avatar
TriGeezer
They make each other.
Old Aug 26, 2020 | 05:59 PM
todd-67's Avatar
todd-67
A lot of them made here. All they are is a series of servo motors, linear actuators and programmable logic controllers.
Old Aug 26, 2020 | 06:51 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
The robots are asexual and the engine/ tranny cases poured in Bangladesh (sic) then everything is assembled at the motor plant in Menominee, WI then shipped to York to be installed in the bike on the line. Which I might add, when the plants open up take the steel toe tour in York, PA. you won't be disappointed. Tanks are cut and formed as well as the fenders, frames welded up, etc. A good tour. I did the engine plant tour many years ago..
