Tread depth
Old Aug 31, 2020 | 09:24 PM
2AMGuy's Avatar
2AMGuy
Community Influencer
I seems to me that one you get near that 3/32nd tread depth that it doesn't take long before you really need to replace the tire.
No way would I start on a trip of any distance with a tire that's getting that close to needing replacement.
I've been caught before where I couldnt'h get a tire replaced and had drive a good distance at a low speed on a tire that looked dangerous.
Also, with the stories that I'm hearing about bearings going bad I'm going to order a complete set of "All *****" bearings and put them in my saddlebags and have them replaced on my next tire change.
Trying to get those last few miles out of a tire, bearing or battery will most likely happen at the most inconvenient time and place.
Old Sep 1, 2020 | 06:42 AM
mazz's Avatar
mazz
Originally Posted by JONNIEROCK
Went into the local Harley Dealership to have some work done. I had just measure the tread depth a week before and haven't put on to many miles since then. The tread depth was around 3/32" to 4/32". Dunlop says a tire has the tread depth of 9/32". While checking in the bike and they've done this before, they said you need a new tire, I said really ? I said what do you consider low tread depth. Their reply was Wisconsin DOT says 3/32 or less is not good, and I had to sign a waver saying that they had told me that it needed a new tire. I didn't read the waiver but I'm thinking it was statement saying they were not responsible in case of an accident. made it sounds pretty frightening if you were just a plain joe off the street. Anyone else hear of such a thing.
Thanks Jonnierock
i think its time to change your tire ,think what you want about signing papers, but that tire has to go and the dealer did right by telling you
Old Sep 1, 2020 | 08:27 AM
JONNIEROCK's Avatar
JONNIEROCK
I found this too. But since it's about cars, i'm not so sure it applies
to motorcycles
Old Sep 1, 2020 | 09:20 AM
FXDXTSport's Avatar
FXDXTSport
Originally Posted by Iron lHorse
That said all NEW rear tires must have a minimum of 12 / 32 “ Tread depth. And yes thats 3/8 of a in .
Not so. As an example, the Dunlop 407 rear that I use (180/55B18) new has 10/32. Others have less. The 408 front new has 6/32.
D407 Spec Chart Tire Name Size Full Tread Depth
D407 BIAS REAR 180/65B16 MT 10/32
D407 RADIAL REAR 170/60R17 9/32
D407 RADIAL REAR 200/55R17 8/32
D407 BIAS REAR 180/55B18 MT 10/32
Old Sep 1, 2020 | 06:59 PM
CanadianRocky's Avatar
CanadianRocky
I will generally run to 2/32, then get a new tire... I have run less than that in the rain, and not had a problem... but I am also not an aggressive rider... If they had asked me for a waver, I would have paid the bill, taken my keys, and waved to them when I left...
Old Sep 1, 2020 | 09:10 PM
s-glide76's Avatar
s-glide76
Motorcycle tires have tread wear indicators built into the tread pattern of the tire.
Just look at the sidewall for a triangle molded into it. There will be a high spot in the tread groove that aligns with the triangle. Once the tire wears down to that high spot it's time to replace the tire.
Old Sep 2, 2020 | 11:45 AM
95th 1200's Avatar
95th 1200
I had a guy come in for a rear tire this past Saturday, was squared off and worn to around 1/32". He asked how many more miles he should go before replacing it, my reply was "none, you need a tire now". His front tire was also dry rotted and falling apart, which he declined. The tires are the only thing between your bike and the ground, if you feel comfortable running them until they're slicks, have at it. Even fair weather riders are susceptible to being caught in a pop up rain shower, that's where having sufficient tread depth makes a big difference. I'll suggest replacement when a tire reaches 3/32", is 7 years old or older, or has visible signs of deterioration.
Old Sep 2, 2020 | 11:54 AM
Bandit.'s Avatar
Bandit.
If your tires are 7 yrs old you own a garage or trailer Queen. If you're getting more than 2 seasons on a tire you aren't riding that bike much either.
Old Sep 2, 2020 | 05:04 PM
carlgrover's Avatar
carlgrover
I tried all ***** bearings once and had to throw them away at the next tire change. They were flaking apart. I went back with Timkens.
carl
Old Sep 2, 2020 | 08:52 PM
Iron lHorse's Avatar
Iron lHorse
Well that’s about 75% of us .
