Torque
Old Jul 31, 2007 | 10:08 PM
ChromeJunkie's Avatar
ChromeJunkie
Default Torque
How does Harleyfigure it's torque on the TC88's? They advertise 85 lbs of torque, but with S&S 510G cams, freeflowing air filter, andless restrictive exhuast, mine is only putting around 80 lbs on the ground. Was reading an article in AIM, and a 95 was only putting around 90 on the ground. Is this number at the flywheel, or is is just false advertising?
Old Jul 31, 2007 | 10:11 PM
YUCK's Avatar
YUCK
Default RE: Torque
I'm putting down about 65hp...
Old Jul 31, 2007 | 10:17 PM
ChromeJunkie
Default RE: Torque
Since they don't advertise hp in their brochures, either printed or online, I'm not sure how many horses a stock twinkie puts out, my local svc mgr sez high 50's-low 60's, but not really sure it thats on the ground or flywheel....My hp to the ground is about the same as torque....78-80.
Old Jul 31, 2007 | 10:36 PM
xxxflhrci's Avatar
xxxflhrci
Default RE: Torque
Their number is measured from the crank
Old Jul 31, 2007 | 10:53 PM
ChromeJunkie
Default RE: Torque
Thanks XXX, understand now how their torque is so high. Was wondering if something was wrong with my bike, since I'm only doing 78-80 with a few mods.
Old Aug 1, 2007 | 08:27 AM
geargrinder's Avatar
geargrinder
Default RE: Torque
Yes, they measure at the crank using the SAE J1349 atmospheric correction factor for net TQ. They also use the RPM step method, stepping the engine's RPM to a given RPM and having the load controlled engine dyno hold it there for the TQ reading, Vs the RPM sweep test that we use on chassis dynos. The step test method also provides higher numbers then if they were using the sweep method. HD does not provide the very importantHP #s for obvious competitivereasons.
Clayton24
Engine Mechanical Topics
23
Oct 7, 2017 04:10 PM
galaxyfe
Aug 22, 2015 07:33 PM
dan conner
Dec 12, 2011 07:55 AM
Vector
Aug 10, 2007 03:14 PM
Fred00
Apr 18, 2007 11:54 AM
