Hey jarred got any pics of the bike with the narrow front end?
If so post a front shot of both to compare please sir. And also a side Pic of both with the 19 inch front wheel.
Looking to do this next on my 01,but I have been looking at the mid glide. And since I have a 19in thunderstar rim wasn't sure it look right with the wideglide..
[QUOTE=Professor Fate;19881415]Shim on the lower bearing would have fixed that yeh only prob remove the new bearing replace. i had none of either couldnt b ****ed waiting. i choose the way in front of me
Shim on the lower bearing would have fixed that right up.
they did supply one with the kit its under the bearing that was supplied just dont think it was enough to stop the binding. removing some of the lower tree to get clearance prob not the way but it works rides nice now had me ****ed for a good month.
Used a local guy Dan @ brugar engineering has a ton of knowagle. Did a awesome job im stoked
Looks good, but I couldn't help noticing the front tire is rotating in the wrong direction. In addition, the turn signals are oriented toward the sky while the headlight looks to be pointed downward.
