Valve service interval ??
Old Jun 15, 2021 | 12:30 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
I remember recommendations to replace the EVO engine lifters at around 35K miles, has that migrated into the Twin Cam, because this is the first I've heard about the TC interval.
Old Jun 15, 2021 | 12:44 PM
Tommy C's Avatar
Tommy C
The 110's developed a reputation for lifter failure due to heavy valve spring pressure paired with poor quality lifters.
Old Jun 15, 2021 | 03:53 PM
Uncle G.'s Avatar
Uncle G.
I had a tappet roller spit its needle bearings at 46,000 miles on my Evo. It cost me a motor after the pieces migrated through the lower end. After that I no longer trusted Evo lifters, even the improved versions, and I got really good at changing them.
So how often am I supposed to change the lifters in the M8?
Old Jun 16, 2021 | 07:30 AM
pgreer's Avatar
pgreer
I haven't seen anything specific about the M8 lifters failing, but I would tend to think about replacing them at about 25-30k miles, or if they became noisy. Reason being is that with the M8 engines, one cam lobe, lifter, pushrod and rocker arm is opening two valves and compressing two springs at the same time. That puts a lot of additional stress on the rocker arm down to the cam, when compared to previous HD engines.
The good news is that the M8 heads flow well enough that you don't need to open the valves .600+, which would require stronger valve springs, to get good performance out of it. But even lower lift cams with faster ramps still add to the stress on the valvetrain.
Paul
Old Jun 16, 2021 | 12:02 PM
RK4ME's Avatar
RK4ME
Paul
I don't know much about the M8 engine but I have to believe that their valves and springs are smaller and lighter than those in the TC cyl head.
To engineer and build a production engine in which the valve lifters have to be replaced every 25K to 30K miles would be major mistake.
How many "miles" do you think the prototype M8 engines were bench tested for? My guess would be for well over 100K miles and to point of failure.
Old Jun 16, 2021 | 12:13 PM
eighteight's Avatar
eighteight
I`m sure that is correct and the same was done during development of the T/C , yet the tensioner issue came to light when the bikes went out into the "real world"
Old Jun 16, 2021 | 01:11 PM
RK4ME's Avatar
RK4ME
I think the tensioner issue was actually a Quality Control issue with a batch of timing chains or tensioner shoes, maybe from a "low bidder".
When I swapped mine for hydraulic tensioners at 50K miles, the shoes looked like they could go for another 20K miles. I ran Syn3 in all 3 for all of those miles.
Old Jun 16, 2021 | 01:36 PM
pgreer's Avatar
pgreer
Yeah, there are lots of cases where people drove EVO, TwinCams and M8's 40-50-80k miles with no lifter problems. But there are enough reports where that was not the case, and the results can be catastrophic in terms of damage done. The early failures are likely due to riding style, like a lot of idle and around town riding time etc. So it is up to each owner to decide if and when they will be replaced, but for me I'd rather replace them too early rather than too late.
And yes, the M8 valve springs are a little smaller, but the seat pressure is not half of a TwinCam or EVO engine. So you still have more pressure on those parts, and you also have a different rocker support system that has had some failures where the rocker shaft mount point on the head breaks off on high lift, fast ramp cams.
Paul
Old Jun 16, 2021 | 01:53 PM
RHPAW's Avatar
RHPAW
I remember a long time ago, when my Evo didn't "feel" right to me. When I dug into it, the rollers in one of the stock lifters started falling out into my hand. I counted them to make sure none of them went into the bottom end.
Then I replaced them all with a better aftermarket brand and rode another 100,000 miles (so far).
Old Jun 16, 2021 | 01:56 PM
eighteight's Avatar
eighteight
^ Same experience on a Shovel many years back
Heard a noise, trailered it home , tore it down "just in time"
