The answer is there is no firm answer for all models and years. In general the 2001- 2004 used a 4 pin connector with 4 pins used. 2005 - up that used the 4 pin connector only used 3 pins in them. In 2012 - 2013 some models switched to a 6 pin connector and most of those 6 pin connectors had 6 pins. In 2014 more models switched to the 6 pin and they dropped to only 5 pins used. In 2018 all models switched to the 6 pin and they all still use 5 pins. In 2021 it has switched again to a different style 6 pin connector and only 4 pins are used.
