Battery recommendations?
Old Jun 30, 2021 | 08:30 AM
Pbertrand102's Avatar
Pbertrand102
4th Gear
Thanks for the heads up
Old Jun 30, 2021 | 09:08 AM
RK4ME's Avatar
RK4ME
I buy Deka AGM batteries from my local Family Farm & Home. AFAIK, Deka makes the OEM Harley batteries. Make sure you get the correct CCA for your bike.
Old Jun 30, 2021 | 09:37 AM
Redlegvzv's Avatar
Redlegvzv
Opinions on Harley's own lithium battery? Anyone out there using it?
Old Jun 30, 2021 | 10:10 AM
BigDawgQC's Avatar
BigDawgQC
There really only two battery makers for powersports in the USA. East Penn/Deka & Johnson Controls. The stock OEM battery comes off the same battery line as: Big Crank/Deka/ThrottleX/O'Reilly/Duracell gray case/NAPA/Duralast & others. They have also made batteries for Yuasa. Interstate is made by Johnson Controls. But the Duracell gray case, it has a two year warranty & you can pick it up at Batteries Plus & cheaper than OEM. It's the one I use. There is a black case Duracell also, but made in China. Yuasa are great batteries too. Drag Specialties I believe are Yuasa made.
Old Dec 30, 2021 | 06:03 PM
lightweight bob's Avatar
lightweight bob
Default No
No
Old Dec 30, 2021 | 06:11 PM
lightweight bob
Default Go first class ..............
Don't cheap out on a lithium battery and get stuck. The battery racers use in some superbike teams is made here in the USA - Speedcell
Here - https://shopspeedcell.com/collections/all
Just be sure to get the correct charger like this one -
Amazon Amazon
Old Dec 30, 2021 | 08:49 PM
85RoadsterXLS's Avatar
85RoadsterXLS
Replaced mine 3 years ago from batteries plus. Still going strong. just an fyi. lots of experience on batteries on here.
Old Dec 30, 2021 | 08:53 PM
gerald martin's Avatar
gerald martin
Get it from the Harley dealer. That way the cables hook up right and you dont need those stupid little spacers that come loose
Old Feb 10, 2022 | 10:36 PM
CHUDDLESTON's Avatar
CHUDDLESTON
I just ordered a "Mega Crank" from batterymart.com $89.95 and free 2 day shipping. The Big Crank is backordered until 3/1/22. Stats looked a little better on the Mega Crank. This one is for my 03 Fatboy, but I may look into the Duracell gray case for my Ultra after reading a little further down in this thread. I have seen them available in my SAM's Club. Thanks for all the info guys.
Old Feb 11, 2022 | 05:07 PM
HildasRevenge's Avatar
HildasRevenge
Replaced mine with a Deka. Keep it on a tender and have had no issues so far.
Got it from a local battery dealer and it is a direct fit and wired right up.
