ATF in primary....
Old May 5, 2022 | 08:00 AM
USMC1911's Avatar
USMC1911
Originally Posted by K. Lindberg
https://www.oildepot.ca/is-atf-suitable-harley-davidson-primary-chaincase-use/
Read the above link, determine if that company is trustworthy.
Good luck.
As if the link specifically pushing a brand is trustworthy. The claim that atf is to thin to provide protection to chains and gears is laughable. As if transmissions, transfer cases and the like dont have these parts. I do agree it is thinner and if you feather and slip your clutch a lot the lack of its ability to coat can lead to premature clutch problems and/or glazed steels.
Old May 5, 2022 | 12:25 PM
K. Lindberg's Avatar
K. Lindberg
"We contend that a thicker oil will provide superior metal-to-metal wear protection. Chains and sprockets will last longer using a fluid with an appropriate viscosity.
Below are the kinematic viscosity numbers for AMSOIL Signature Series Multi-Vehicle Synthetic ATF, AMSOIL V-Twin Synthetic 20W-50 and AMSOIL V-Twin Synthetic Primary Fluid. The viscosity is measured at 100°C.
  • ATF- 7.5 cST
  • 20W-50- 18.5 cST
  • Primary Fluid- 18.7 cST
cST = centistoke *
Compared to 20W-50 motorcycle oil and the dedicated primary fluid, ATF is very thin.
For reference purposes, ATF has a similar viscosity to 5W-20 motor oil."
If one forget about Amsoil brand and just consider the tecnical parts, then the above sounds plausible at least to my ears.
But You most likley have a much better knowledge compared to me, so I would never imply that the above is the only truth.
(It's always good to read the comments from someone with a vast experience and knowledge).
* Centistoke (cSt) is used to report the kinematic viscosity of motor oil at high temperatures.
The number reflects the time required for a fixed amount of fluid to flow through a certain sized orifice on the testing device.
Old May 5, 2022 | 12:42 PM
RK4ME's Avatar
RK4ME
Originally Posted by TriGeezer
Well, what I don’t recommend is Syn3 in the primary. Maybe it’s because I had Se255 cans in my heavy *** TriGlide, fully loaded with luggage , and riding 2up…but the clutch slipped & chattered. Even after draining the primary and changing back to F+…the clutch plates were burnished
I ran Syn3 in all three holes of my '04 Road King for its first 50K miles, and it performed well.
I wonder if the clutch in your Tri Glide was designed for that kind of a load. Does the owner's manual recommend Formula+ for your Tri Glide's primary?
Old May 5, 2022 | 01:20 PM
s-glide76's Avatar
s-glide76
  • ATF- 7.5 cST
  • 20W-50- 18.5 cST
cST = centistoke *
I agree that a heavier oil is better for chains and sprockets, I think a thinner oil is better for clutches. My thinking says a thicker oil will cause more clutch drag and retain heat longer.
But I also just run Rotella T4 15/40, it's rated JASO MA2 for wet clutches and you can buy a gallon of it for $15 at Walmart.
Old May 5, 2022 | 03:37 PM
dsc2's Avatar
dsc2
6th Gear
Ran Rotella 15/40 for years in my Asian bike and now in the primary of my 2014 Sportster, no issues. Rotella is very common among the offshore bike crowd, JASO rated and affordable.
Old May 5, 2022 | 04:52 PM
Jehu's Avatar
Jehu
Rotella is good oil. My metric bikes, which utilize a common reservoir for engine and transmission seem to like it just fine even with more horsepower, more torque, more revs and doing triple duty all at once, engine, transmission and clutch.
The H-D primary is fairly rudimentary assembly. The H-D recommended fluids (Formula+ and Syn3) are probably just fine - especially the former. While I did not and will not use Syn3, I have used Formula+ and, like i said, it's just fine. However, I do seem to have better clutch feel - release and grab with ATF Type F so I stick with that and get a free beer or two with every quart in so far as cost versus H-D brand oil.
For me, it probably don't make that much never mind which oil is used in the H-D primary case. I like the grab and the release that Type F provides as well as the free beer.
1Fordman
Shovelhead
Jun 18, 2018 08:15 AM
jmn1960
Mar 26, 2013 06:03 PM
TCMAN
Apr 2, 2011 07:20 PM
Roses
14
Oct 11, 2009 02:01 PM
OneBlackFly
Sep 13, 2007 12:48 AM
