Rain pants melting on my pipes!
Old Aug 15, 2007 | 05:27 PM
txgeezer's Avatar
txgeezer
Default RE: Rain pants melting on my pipes!
Been there, done that before.....The Easy Off Oven Cleaner sounds good. I think I used kerosene and a plastic dish scrubber....but my wife swears that you should soak a rag in amonia, wrap it around the pipe, covered with tin foil overnight and you can wipe it right off in the morning. Thats worth a try before you go get radical.
Now here is the poor man's funny fix for your future. After it happened to me I always kept a cut off pant leg in my saddle bag. I would put on the rain suit and stick my leg in the old pants leg. Looked tacky but it kept the rainsuit from melting again!
Old Aug 15, 2007 | 09:37 PM
madden23's Avatar
madden23
lol, I let my son borrow my bike he took off in shorts and sneakers to run to store he melted his leg on my pipes getting off it, silly boy. windex did the trick
Old Aug 16, 2007 | 04:25 AM
Navychief's Avatar
Navychief
What are rain pants?
Old Aug 16, 2007 | 09:49 AM
grumpy irish again's Avatar
grumpy irish again
good question I think they are those yellow things I found I the garage awhile back at least that is what I am taking with me to regon in sept.
ORIGINAL: Navychief
Old Aug 16, 2007 | 01:46 PM
SteelCityScooter's Avatar
SteelCityScooter
ORIGINAL: Navychief
OMG.... thank God for the lowly Seaman Recruit's to PO1"s, ... or the Canoe Club would still be in port....... sheesh Chief quit polishing those gold anchors and get out there and ride.... you really won't melt.
Old Aug 16, 2007 | 01:58 PM
sjhsc's Avatar
sjhsc
Guys in a forum for my previous bike would sew some material from an ironing board cover on the bottom of their rain pant leg. It's made to take high temps. Just make sure that you water seal the seams.
Old Aug 17, 2007 | 02:56 AM
nighttraingirl's Avatar
nighttraingirl
I have seen the ironing board cover trick also. You could always sew the ironing board cover to a wide piece of elastic and then just slip that over your rain suit leg. That way you don't have to worry about heat sealing.
Old Aug 17, 2007 | 01:25 PM
FLHRCI_King's Avatar
FLHRCI_King
I have kevlar sleeves that are made to wear on your forearms when working on hot engines or other applications where you could burn your forearms.
I stretch one over each rain pant leg and it protects the lower portion of my legs and it keeps my rain pants from flapping in the breeze. They are dark blue and actually blend in with my rain suit.
Now if I could keep the jacket from leaking water around my neck I'd be good.
Old Aug 17, 2007 | 02:07 PM
kerberos's Avatar
kerberos
Yer not supposed to wear 'em on your pipes!
Old Aug 17, 2007 | 05:03 PM
shoptroll's Avatar
shoptroll
Isn't that a song ? Rain pants keep meltin' on my pipes....................................
