I’d vote for repair - bypass the weak terminals, solder in some heavy wires with new insulated female terminal ends and Velcro the new fuse in place. Any high amp 12 volt circuit is susceptible to this. My ‘91 EVO fried the big red wire connector under the dash, was at a friends house over night, bike ran fine the day before no power the next morning. Traced it with a circuit test light finally figured it out, he had a wire nut got me home. I soldered that POS connection never another problem.
I have a dim opinion of these “modern” connectors Harley uses now, not enough spring in the metal female side of these things. My ‘04 FLHR voltage regulator connector similar problem, didn’t melt but weak connectors caused a low voltage charge problem, used an oring pick to push the terminal sides back towards center. That 50 amper, once repaired time for functional test, I’d run the bike with all accessories/lights on and feel for heat at the fuse and it’s connections.
Ordered new parts today for Maxi Fuse holder. Price of parts was surprisingly very reasonable and access to remove and replace is also straightforward.
I am back up and running after cleaning terminals and installing new fuse, but once parts arrive, I will be soldering in new terminals and replacing terminal holder etc. with new parts.
Thanks for everyone's input and help with this issue.
You get a better electrical connection with solder and heat shrink vs crimping. I think in this scenario that is what's important. Happy to agree to disagree though.
Once the repair is completed I’d check for excess heat at the connections and the fuse itself, just to be sure! Bike running, all lights on, hold the brake to activate that light too.
Very few things are soldered in life, other than tiny electronics. From 3000 amp connections to your battery, starter, ect.
With a crimp the wire is 360 degrees in connector.
Crimps just are not used much. Add on top it may be brittle.
Crimping offers stronger, more reliable connections than soldering. Soldering uses heated metal to join the cable to the connector. Over time, this filler metal will degrade, which may cause the connection to fail.
I think you'll be ok. But I don't think it offers the advantage people think. Crping does require special tools.
