Fobo tpms
Old Sep 2, 2022 | 06:01 PM
  #41
TriGeezer's Avatar
TriGeezer
Originally Posted by TexasScooterTrash
Welcome to Pussfication of the American Male. Check yer tire pressure regularly, with a tire pressure gauge it only takes a few minutes and it cost under $10. It one of the things ya do before ya ride.
NOW I know why there is a LIKE button and no laughing face button to click.
With the FOBO I can easily check air pressure before each ride. And it lets me know if I’ve developed a leak during a ride. If technology is the pussificatiin of America, then Throw away your pc, and cell phone.
Old Sep 2, 2022 | 08:17 PM
  #42
YZR's Avatar
YZR
Hey texasscootertrash, are you glad you called us out as pussies?
Old Sep 3, 2022 | 03:00 AM
  #43
Redlegvzv's Avatar
Redlegvzv
I have been using the newest version of the FOBOBike system for several years now on my Road King and I really like it. Firstly, it is fine for rubber stems. The caps are very lightweight; largely made of plastic. I’ve done 15000+ miles with them. The app works great on iPhone and Apple Watch. The later FOBO version corrects the welding issue that the earliest version had.
Old Sep 3, 2022 | 08:30 AM
  #44
r-bar-j's Avatar
r-bar-j
I ordered FOBO System from Amazon yesterday. Supposed to be here today, will install in the morning. Looking forward to not crawling around to check tires.
Old Sep 3, 2022 | 09:22 PM
  #45
skratch's Avatar
skratch
Old Sep 5, 2022 | 03:15 AM
  #46
adm's Avatar
adm
The only problem you will have is that you will still have to crawl around to adjust the air pressures. Knowing exactly what the air pressure is means that there will be more times when you say "Well, that back tyre is about 2lbs low. I'd better put some air in it".
Sometimes, ignorance is bliss if you are a bit OCD like me.
Old Sep 5, 2022 | 03:18 AM
  #47
adm's Avatar
adm
Old Sep 5, 2022 | 06:27 AM
  #48
Tjroadie's Avatar
Tjroadie
My experience with the Fobo is to set the psi 1 lb high on a cool morning. 10° ambient temp say from 60° to 70° am can raise pressure 2# and riding pressure on my UL the front typically raises 4- 6# and the rear 8-10# so don't try to stay dialed in on a specific pressure. I haven't found any significant air loss that I need to add air but every couple months morso due to weather conditions. Also you set the alarms high and low, I set mine 2 lbs low and 10 lbs to avoid the alarm constantly going off.
Old Sep 5, 2022 | 08:58 AM
  #49
Ssitruc's Avatar
Ssitruc
PSI changes in tires 1psi for about every 10 degrees F of temperature change. All "recommended" psi values are based on cold, which uses 68F as a reference point (and not ridden yet)... If it is 80F in the morning, before you have ridden the bike, and you're checking your tires, they should show 1 PSI higher... if you're getting real technical about it. If you've been out riding and tire are heated up, and need to add air you are really just guessing because you have no idea what the tires temperature actually is.... so just air it up to a safe level, then the next morning when the tires have cooled and they are at ambient temperature, and has not been ridden yet, then get it back where it should be. The "tire temperature" on the FOBO's, or any valve stem cap system, is no where near what the real temperature in the tire is. Front tires on touring bikes (and the air inside them) in the summer easily get to 120-140F and rear tires 140-160F (and higher)... but on the tip of the valve stem no so much.
Old Sep 5, 2022 | 09:20 AM
  #50
Tjroadie's Avatar
Tjroadie
edited reply hope this makes more sense!
