Tachometer Question
Old Sep 7, 2022 | 07:01 PM
Dseago1969's Avatar
Dseago1969
Ok, I’m used to inductive rpm and timing lights. This on is a bit different, there are settings depending on spark per revolution. It sounds like this one is set incorrectly. Take a look at the pdf @RIPSAW sent a link to. Idle should be around 9-1100. Get that right and it should be correct.
Old Sep 7, 2022 | 08:11 PM
Wagondog's Avatar
Wagondog
Dseago Thanks for the info, the model RIPSAW posted is the 2a and gives the ability to reset. The one I found is not resettable nor does it have the select button
I remember using this Tiny Tach on my 03 Sportster just to check rpm. I believe I took the reading on the meter and doubled it for the rpm. Been a long time in the tool box
Old Sep 7, 2022 | 08:19 PM
brakeless's Avatar
brakeless
@brakeless if they are a good quality they are very accurate. I used to use them tuning hot rods back in the day because they were more accurate than the analogs I ran. They have been used for timing for decades.
Well I'm only going by what I read on a LawnTractor Forum. I was trying to set the idle on a B&S VTwin I rebuilt and found some on Amazon and at Harbor Freight. But they were cheap.
Old Sep 8, 2022 | 07:49 AM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
Wrap it on both wires.
Old Sep 8, 2022 | 07:30 PM
Cap77's Avatar
Cap77
don't know about lawn mowers, Brake
But I've used them on power equipment for years (Tiny-Tac brand specifically)
The only failures I can recall in 20+ years of using them is the hour meter stops working.
but the tac still reads
when you run the equipment daily, you can tell the RPM within a coupe hundred revs without tac
Tiny-Tac has always confirmed what I hear and has stayed consistent "forever"
just my experience
..L.T.A.
Old Sep 10, 2022 | 03:53 PM
Old_Bikes's Avatar
Old_Bikes
If you are worried about oil pressure, don't worry about a tach. Get an oil pressure gauge.
Old Sep 10, 2022 | 09:21 PM
Wagondog's Avatar
Wagondog
Thanks for your words of wisdom
Old Sep 10, 2022 | 09:53 PM
RANGER73's Avatar
RANGER73
As our Harleys have a wasted spark your "tach" is reading a spark that does nothing.
So it's reading twice as much as it should be.
Old Sep 10, 2022 | 09:54 PM
johndoe297's Avatar
johndoe297
No shortage of those around here.
Old Sep 11, 2022 | 05:10 AM
Wagondog's Avatar
Wagondog
Thanks Ranger.
Its been many years since I used Tiny Tach. I forgot that it reads half of the actual rpm. Set it at 500 and thats where it likes to be, 1000 rpm
