Shinko tires: Fill it to the Max!
Old Jun 8, 2023 | 08:23 PM
hellonewman's Avatar
hellonewman
Originally Posted by strych9
That's all well and good, and I respect your experience and history about them. Does any other tire manufacturer insist on inflating their tires beyond the motorcycle manufacturer's recommended pressures in order for them to wear properly? I know of none. Over-inflation beyond vehicle engineers' recommended pressures produces a harsh ride and differing handling characteristics. I see this as the tire manufacturer compensating for a tire design flaw. Not cool.
Tires are like oil; nobody's going to agree on what's best. I also believe Shinkos are generally the least expensive tires on the market, and I have to wonder why. My one experience with Shinko tires came with my Vmax purchase. That bike had a brand-new set of Shinkos on it when I bought it. After a 200-mile break-in, they did not instill confidence in my ride. They felt "greasy". I replaced them with the high-dollar Bridgestones that were OEM for those bikes and it now handles as it should at OEM pressures.
In fairness, I ran those Shinkos @ Yamaha pressures. I wasn't aware of their "max-pressure" recommendation. Still don't think that's right, but alas; I just won't ever buy Shinkos. I sold the pair I pulled off the bike for $50. New owner was tickled.
The manufacturers suggested inflation pressure goes out the window if im running a tire that didn't come on the bike from the factory. The fact Harley used the same shocks on the rear of a touring bike pre-08 weenie rear tire then 09 up with the 180 rear tire with considerably more unsprung weight tells me the chassis isn't highly tuned and variations in tire pressures and brands isn't going to upset anything except the rider apparently.
Old Jun 8, 2023 | 08:46 PM
downzero's Avatar
downzero
Originally Posted by jake24lt
Pressure also affects the contact patch area size of the tire, as well.
Right, which is taken into account when the manufacturer recommends a particular pressure for a particular tire size. That doesn't change when you replace that tire with another one of the same size/volume.
Originally Posted by tmac00333
So when you replace an OEM tire with an aftermarket tire, let's just say a Metzeler for example, you don't use the recommended tire pressure the Metzeler gives you? You use the original recommendation for a completely different tire?
First, I've never bought a tire where the tire manufacturer recommended a tire pressure. On my motorcycles, I've only had Dunlops on street bikes of different designs, OEM and the American Elite. But I've also bought tires for dirt bikes and cars/trucks and to date, never had them "recommend" a pressure. That includes B.F. Goodrich, Interco, Michelin, Goodyear, Nitto, and probably a few others. All have given me a max pressure for max loading. None have ever given me advice as to what pressure to use. I have used tires at 25 psi that have a max of 65. Hell my factory vehicle tells me to use 40 psi in an 80 psi max tire at low load.
Additionally, it is not a "completely different" tire to replace one tire with another brand of the same size and volume. The two tires have the same amount of air in them and thus the same carrying capacity. Obviously that's not true if there's a drastic difference in the load range/carcass construction of the tire. But I also don't alter that from factory--I shop for tires in the same load range/construction as the ones that came off.
So I think you're mistaken as to both claims you're trying to make. I didn't disregard a recommendation for pressure because there hasn't been one with any tire I've ever bought. And I don't regard it as a "completely different" tire. It's the same in all relevant respects and it gets the same pressure to support the same load, even if it's a different brand or tread pattern.
Originally Posted by WXSW
If the factory rep is saying do it, and you’re not exceeding the max pressure, why not give it a try, at least to experiment. I think the best tire pressure will vary from bike to bike. I don’t inflate the 50 psi max rated Brazilian ME888 on my FLH to the max, and run them around 40, because that’s what I was already running the German ME8888’s on my other bike at and it seems to work pretty well. Both bikes, a Shovelhead FLH and a Moto Guzzi California 1400, weigh about the same, the Harley being a little lighter.
If the tire manufacturer is telling me to do something other than what the factory that designed my vehicle has recommended for the same use/circumstances, that makes me skeptical of both their opinion and their product.
Wrong. The recommendation is for a size, load range, and pressure, not for a particular brand of tire.
Old Jun 8, 2023 | 08:50 PM
TexasScooterTrash's Avatar
TexasScooterTrash
I'm running the inexpensive Shinko's on my 1977 XLH 1000. Review- AWESOME. Would I put Shinko's on my Wife's 04 1200 Custom or my 07 Dyna? HELL NO.
Old Jun 8, 2023 | 11:21 PM
tmac00333's Avatar
tmac00333
Exactly. It's a different tire, made differently with different components. The manufacturers suggested tire pressure is for the tire that came with the bike. There's no way HD can make a recommendation for a completely different tire they don't know anything about.
It's like if you did a stage 1 and used a Power Vision tuner. If you were looking for suggestions on how to use the PV, would you call up HD?
Or put another way: Would you ask Metzeler for a recommendation on HD OEM Dunlops?
Old Jun 9, 2023 | 06:57 AM
skratch's Avatar
skratch
i replaced my tires before taking a 3,000 mile roadtrip earlier this month. i had been trying for over a year to get a set of avons, but no luck. at the time, ae, bridgestone, pirelli, etc. were all on backorder. i wasn't sure when i would be at the limit, so i had to buy a set of shinko 777's to at least have something on hand. those tires made the roadtrip just fine. sustained speeds of 80 mph, no problem. didn't run into any rain, so no data there, but otherwise, they performed well. now just have to see how well they hold up, but if i can get at least 2 seasons out of them, i'll be fine with that.
Old Jun 9, 2023 | 07:28 AM
strych9's Avatar
strych9
That is incorrect. As Downzero states, tire pressure is based on tire size and load, and application. Some bike manufacturers use the exact same tire as a competitor, with the exact same specs, yet recommend different pressures than each other. There is a reason for that.
100% this. I have attended engineering classes for FoMoCo and this was a topic of conversation.
See my comments above. I'll also point out that Shinko is not an OEM tire for any manufacturer, at least none that I am aware of. Why is that?
Old Jun 9, 2023 | 07:41 AM
hellonewman
Apparently you're wrong too because the Shinko engineer (are you a tire engineer?) said to inflate to max which contradicts HD's suggestions on a tire of the same volume.
We're not dealing with Nascar racing or F1 here, it's an antiquated motorcycle that can't get out of its own way so take a chill pill.
Old Jun 9, 2023 | 08:03 AM
hellonewman
Not according to Shinko. I think you and big zero are making a mountain out of a mole hill.
One of my sport bikes came from the factory with two different tire brands front and rear and today I can't get the same size rear or brands front and rear (170 rear so now run a 180 and run a pressure that the tire and I are happy with). Something people on this site say you can't but for what reason? Honda engineers must be stupid for fitting two different brands but we all know better. What are we apparently fretting about because I have no idea. Certain death or tire failure or?
I inflate my tires and watch the wear to decide if Im too high or too low regardless of the suggested settings. Hard tail bikes depending on circumstances you run in the 20's for the rear despite the inflation spec because the bike has no suspension and its makes the rider happy. .
Old Jun 9, 2023 | 12:24 PM
Calif Fat Bob's Avatar
Calif Fat Bob
Ahhhh nothing brings out a spirited discussion like Air Pressure or Oil brand/viscosity in bike and car forums. Lol
I've only had one experience with Shinko tires (705s) on my KTM Adventure bike, and will not be using them again, They had great reviews but for me they did not feel stable at speed for my bike.
With so many choices in quality brands (Dunlop, Metzler, Avon, Pirelli, Michelin, etc) I stick with what Harley uses or a quality alternative. Shinko does fills a need for lower cost tires.
For what it's worth, I recently installed Metzler Cruistecs on my Fat Bob and I will be installing them on my Low Rider ST soon. Really great tire for aggressive handling on these big bikes.
Old Jun 9, 2023 | 01:05 PM
Halojumper's Avatar
Halojumper
Originally Posted by M Oclaf
It’s like running a car tire on a bike, sure, you can do it, but it doesn’t mean one should.
Oh boy, you're gonna open a whole new can of worms with that one!
