Minimum Ride Time / Start
Old Dec 1, 2023 | 01:54 PM
downzero's Avatar
downzero
Originally Posted by hellonewman
If the exhaust is hot enough to remove your finger prints, it'll dry up any condensation in the system.
It's the oil you want to warm up every once in a while.
My office is also 4 miles from my house, but I ride enough when I'm not going to work, or even around town during the work day sometimes, that I'm sure it does just fine.
Old Dec 1, 2023 | 01:58 PM
BrandonSmith's Avatar
BrandonSmith
Active Streak: 30 Days
OP, take a longer route to work.
Old Dec 2, 2023 | 07:30 AM
Herrick's Avatar
Herrick
Originally Posted by Calif Fat Bob
I might as well junk both of my bikes as I start them up nearly every other weekend just to get a chubby from the exhaust note and to cycle the battery on the tender. Let it run maybe 3-4 minutes and shut it off. I tend to change my oil in bikes and cars especially when new, may more frequent than manuals recommend. But then again I live in the SF Bay Area, CA so I don't get the temperature swings some of you experience.
What does that do for the battery when you run the bike while the battery tender is connected? Serious question. I've never done that before.
Old Dec 2, 2023 | 07:51 AM
smitty901's Avatar
smitty901
Your bike do what you want with it.
But if you start it while store and it does not get and stay at 180 degrees oil temp for a fair amount of time it will not cook off the moisture. When you shut it down that steam will just settle back down in the oil and lubes..
You parked it let it be.
Old Dec 2, 2023 | 10:51 AM
Taxgod4u's Avatar
Taxgod4u
Wouldn't the water get boiled off when it is in the screaming hot heads while at chubby generating garage idle?
Old Dec 2, 2023 | 11:50 AM
Cosmic Razorback's Avatar
Cosmic Razorback
Community Influencer
Ever have your bike or car sit for a week or two. You start it up and see water drip from the exhaust. That is the condensation you do not want and you need to burn off.
All the fluids need to get up to full temp and everything be lubricated.
I have no problem with my bikes sitting for two to three weeks on the tender. I simply do NOT start them. They cannot warm up enough idling for 5 to 10 minutes.
Riding to the office or home for just 7 miles each is not a problem unless that’s all you are doing. Every other day ride 20 miles and you’ll be good.
Old Dec 2, 2023 | 04:05 PM
Rounders's Avatar
Rounders
Originally Posted by Goose_NC
Every 5-7 days I ride 40-60 miles one way. My office is 6 miles away. But I mostly work from home now.
The issue with short trips is the condensation build up. A 20 mile ride will get the bike to temp and burn off that condensation.
Short trips are not good for any gas vehicle.
And member use a tender because it is not getting a good charge. Though I am not sure I would overly worry about it, if you are getting one good ride a week. If you really wanted to you could change the oil more often.
Could run dino oil, which may get warmer faster, and cheaper to replace. But you could argue the syn will be better for cold starts, which, I lean to this if 30s or 40s. If warmer cheap oil and change 1-2 months.
Old Dec 2, 2023 | 04:08 PM
Rounders's Avatar
Rounders
Originally Posted by Grouser62
I. In any event you’re taking a short trip with your bike or your car, six of one.
But chances are your car is getting long rides, especially in winter. In summer I agree, then you need to take your car for a long drive. If my truck has been parked for awhile, I'll just go take it for drive nowhere.
Old Dec 5, 2023 | 07:52 AM
ksol5's Avatar
ksol5
Once I put my bikes away for the winter(first week in November here, once they start salting the crap out of the roads). I don't do anything with them, I want to start them all winter long but I don't until the covers comes off in April and I start cleaning them and checking everything over again, whether they need it or not.
Old Dec 5, 2023 | 07:59 AM
Bubba Zanetti's Avatar
Bubba Zanetti
Same here, once the brine goes on the road my HDs don't come out of the shed until about April. I gave my Dyna a good bath about a month ago, took it for a short rode to top the tank off, poured in some fuel stabilizer, then hooked her up to the battery tender. Shes been hibernating ever since.
