The bumper on the right shock is about a 1/4" from bottoming out. The left side bumper is all the way down. After my first ride.
After watching their adjustment video, I need to adjust the right side shock. Doesn't make sense to me, but what do I know.
I would not adjust 1 side only. Both need even adjustments from the initial setup. If one side has shorter travel than the other I would call Pro action before adjusting one side only. This way they will know that both shocks are still evenly adjusted and they will tell you what you have to do.
If you have one bumper touching the bottom and the other one is a quarter inch away and you don't feel it bottoming out I would just leave it as it is.
It was my first ride, maybe two miles. We've been having thunderstorms and rain. I was going to head out on Sunday, but now that I have the shocks I can wait until Monday or Tuesday. Hopefully, we'll get a long enough break in the weather on Sunday for a longer ride.
What was interesting is that during the install, the right side bolts lined up perfectly and the left side was off by only a smidge. I do have to take a grinder to the bottom brace of my sissy bar. They were so close to touching the top of the shocks, I don't think that I could have slipped a piece of paper between the two.
And you are correct. I rewatched the fine tuning video and it was the "clicker" that he said to only adjust on the right side. This newer video is only 4 months old and the shocks that he's tuning have the red collar.
that's pretty common. rack and pull has a whole bunch of videos showing how to align your suspension. their claim is that the motor/trans is not aligned properly, causing the swingarm to not be aligned. which results in your shocks not fitting properly, and can lead to wobble.
I have installed three different brands of rear shocks and this is a very common issue. You just have to jack the rear up or down for the second shock install and presto.
I would NOT start playing with the adjustment. If and when adjustment is needed it is always in very small increments. A little makes a lot of difference and you can easily make things worse.
