How long before you change
Old Apr 29, 2025 | 06:10 AM
touchdown's Avatar
touchdown
Default How long before you change
How long before you change the drive belt ? Just turned 60K on my 2019 Ultra, everything looks good to me, no rough spots or cracking.
Old Apr 29, 2025 | 06:19 AM
Rounders's Avatar
Rounders
Myself, I would plan on it some winter or when you have primary off, once you hit 50k. I don't believe in waiting until you are stuck on the side of the road for hours, late for work, or talking to cops. I do inspect on tire changes, but that is every 10k miles, more so with some of these newer tires. Lots of people disagree with me and like being stranded. I also change my oil.
Not saying I rush to do it. But it becomes one of those things that I say next winter I am going to, I may or may not.
I had one pac man at 55k. Another was good at 90. But that was also the old style thicker belt. I would do stator since the primary is off too. I like to get as much done when its open. Both belt changes did stator, and I also did seals on tranny since I replaced the pulley.
People would also scuff at this, but if I had stator out I would consider sprocket shaft seal on crank shaft. I replaced mine at 55k, and I think it had been leaking for a long time.
Old Apr 29, 2025 | 06:28 AM
touchdown's Avatar
touchdown
Ya I was thinking at about 70K or so.I do have an extended warranty so I won't be doing the other stuff.
Old Apr 29, 2025 | 06:30 AM
Notgrownup's Avatar
Notgrownup
Until it shows signs of weakness or damages it’s staying unless I am opening that part of the bike up.
Old Apr 29, 2025 | 06:33 AM
Rounders's Avatar
Rounders
If you have the belt off, you may want to consider it. How long is warranty? You don't want to open it again do you, after the warranty is up? If not doing the work yourself, I would even consider paying for it. Cheaper now.
I'd still consider stator or shifter shaft seal. Primary bearing too, of course. Any time the primary is off, think about that one.
Problem with this philosphy is you check it every 10k? How many miles from once it starts pac manning like mine does, until it fails? But I get the point of doing when primary off. One bike I had to do because it failed, other one I just decided one winter to do it based on age, and replaced everything, more stuff then I listed here actually.
Old Apr 29, 2025 | 06:56 AM
Goose_NC's Avatar
Goose_NC
I would be more concerned with age than miles. I know of many belts lasting over 100,000 miles and up to 10 years. Much depends on how the motorcycle is maintained and ridden, and where it usually lives.
Old Apr 29, 2025 | 07:03 AM
Rounders's Avatar
Rounders
Good point. Lets be honest about how long it takes to put miles on.
Old Apr 29, 2025 | 07:09 AM
elPrez's Avatar
elPrez
I did the belt and both pulleys on my 05 Ultra at about 97,000 in 2023. The engine had a cam bearing disintegrate at 99,091 miles so that was special and totally unrelated.
Old Apr 29, 2025 | 07:29 AM
RHPAW's Avatar
RHPAW
Check the rear shift rod for slop while you're in there. It's the only time you can really get at it, and those splines are a known weak point (front too).
Old Apr 29, 2025 | 11:14 AM
14GuineaPig's Avatar
14GuineaPig
I had 2 UC & 1 Limited pass 100,000 miles on the original belt. I have a 1994 FLHTP with 80,000 on the original belt. All the bikes were stock amd I don't ride them hard.
