Harley recall
Old Jun 14, 2025 | 10:41 PM
Crunchy's Avatar
Crunchy
Default Harley recall
Info copied from: https://static.nhtsa.gov/odi/rcl/202...5V375-3545.pdf
Makes/Models/Model Years:
HARLEY-DAVIDSON/FLDE/2018-2019
HARLEY-DAVIDSON/FLHCS/2018-2024
HARLEY-DAVIDSON/FLHC/2018-2021
HARLEY-DAVIDSON/FXLRS/2020-2024
HARLEY-DAVIDSON/FXLRST/2022-2024
HARLEY-DAVIDSON/FLHCS ANV/2018, 2023
HARLEY-DAVIDSON/FXRST/2022
Mfr's Report Date: June 04, 2025
Problem Description: Harley-Davidson Motor Company (Harley-Davidson) is recalling certain 2018-2024 Softail motorcycles. The mounting tab on the rear shock pre-load adjuster may break, allowing the rear shock absorber adjuster to damage the rear tire, causing a loss of tire pressure.
Consequence: A sudden loss of tire pressure increases the risk of a crash.
Old Jun 15, 2025 | 06:58 AM
GalvTexGuy's Avatar
GalvTexGuy
Thanks for the info.
So, the last recall (23V591) was because of an undersized fastener that secures the pre-load adjuster to the bracket. I guess this recall is because of the bracket to which the pre-load adjuster is attached? That bracket mounts on both sides of the frame. Well, that’s just great!
Old Jun 15, 2025 | 09:08 AM
npn's Avatar
npn
They are recalling 82,000 bikes! Has ever been a recall that huge? I'm sure it can't be good these days for HD.
Old Jun 15, 2025 | 03:33 PM
Keithhu's Avatar
Keithhu
Not nearly the largest. https://fortune.com/2018/11/01/harle...0-motorcycles/
Old Jun 15, 2025 | 03:48 PM
Tommy C's Avatar
Tommy C
Looks to be a relatively simple fix. At least it isn't a tab breaking that is welded to the frame.
Old Jun 15, 2025 | 04:50 PM
MesquiteFLD's Avatar
MesquiteFLD
Bikes were much better when they were assembled by people not machines.
I've had 7 new Triumphs since 2003. The first 5 were bullet proof. The last two assembled in Thailand not the U.K. both had problems.
Old Jun 15, 2025 | 06:16 PM
Taxgod4u's Avatar
Taxgod4u
Do any of them drink and ride?
Old Jun 16, 2025 | 04:58 AM
TracerBullet's Avatar
TracerBullet
So, I wonder how long it will take to get the parts to fix the problem?
Old Jun 16, 2025 | 05:01 AM
Toe Knee's Avatar
Toe Knee
Following
Old Jun 19, 2025 | 08:01 PM
Mattbastard's Avatar
Mattbastard
I would LOVE to see how the preload adjuster could possibly fit in that tight space enough to damage the rear tire.
