Lithium Battery Question..
Old Jan 18, 2026 | 04:06 PM
  #31
MURPHCC1's Avatar
MURPHCC1
There are utube vids of how to awaken a lithium.
And if it happens away from home youre on a tow truck, you wont have the charger or electrical power to fix it, and ya cant jump it like a regular battery.
Old Jan 18, 2026 | 07:26 PM
  #32
wis1's Avatar
wis1
For those reasons, I'll stick with "old school" for now ...
Old Jan 18, 2026 | 08:24 PM
  #33
MotoJockey's Avatar
MotoJockey
Yeah........ I like my fair share of technology and all, like I have one of Samsung's newest-bestest cell phones, but these Li batteries are just too damn finicky for my taste. If it had a nice set of fake **** on it, I'd be a little more willing to put up with some of that finicky crap, but............. I'm good with my AGM's.
Old Jan 19, 2026 | 06:30 AM
  #34
danny54's Avatar
danny54
you can jump start a lithium if its dead, All i use in my harley has been lithium
Old Jan 19, 2026 | 07:11 AM
  #35
MURPHCC1's Avatar
MURPHCC1
How?
Old Jan 19, 2026 | 09:58 AM
  #36
wis1's Avatar
wis1
I did a little looking around how to bring them back , everything I found was remedies you would not have along 800 miles from home at some dive bar .
I ordered the Noco harness to hook to my battery , has a pigtail that you can plug a newer series Noco Boost X directly into , comes with an adapter plug so you can use the same plug to plug a battery tender into .
Older bikes = twin cams etc you get at the starter to jump off of , newer stuff, everything is buried ....
Old Jan 19, 2026 | 10:05 AM
  #37
MURPHCC1's Avatar
MURPHCC1
Originally Posted by wis1
I
ordered the Noco harness to hook to my battery , has a pigtail that you can plug a newer series Noco Boost X directly into , comes with an adapter plug so you can use the same plug to plug a battery tender into ...
That still wont jump start a lithium(LIFEPO4) away from home
Old Jan 19, 2026 | 10:17 AM
  #38
wis1's Avatar
wis1
Correct, I've given up on the lithium idea for now. Maybe someday I'll have a lithium, but for now it's old school
Old Jan 19, 2026 | 10:50 AM
  #39
Babyboy's Avatar
Babyboy
I see a bunch of confusion on lithium batteries. I will try to clear up some of this confusion.
Some say once they are dead they are dead which can be true. The reason some of these cheaper lithium batteries die and will not come back is because they DO NOT have a BMS(battery management system).and the battery was neglected. The BMS keeps the cells from going completely dead and shuts off power when they sense voltage below 10.5 vdc. To reactivate the battery all you need to do is hook up a 12v source and let the voltage balance between the lithium and the 12v source. NEVER jump a battery on a bike from a running vehicle as it WILL damage the bikes charging system from over amperage from a running vehicle.
Most lithium battery manufactures have maintainer/chargers avaible for the batteries they produce which I would recommend IF you decide to go the lithium route.
Resting voltage on a properly maintained lithium battery is between 12.8 to 13.2 depending on manufacture. Your bike will start easier and your charging system will last longer as the lithium batteries will charge for a shorter time having a higher resting voltage.
I have been using lithium batteries on my bike for 5 years plus and have had ZERO issues. These batteries when properly cared for will last upwards from 8-10 years. Yes they are expensive on the initial purchase but will out last an AGM or flooded battery 3-4 times over.
Old Jan 20, 2026 | 09:05 AM
  #40
MarlinSpike's Avatar
MarlinSpike
Veteran: Coast Guard
Sticking with AGM's in all my vehicles. Tried the Shorie route - not for me.
My last year of work, we did Lithium starter battery testing for Embraer aircraft. If you ever seen a lithium blow up, you will probably never put one in your bike.
Impressive, incredible, total massive destruction in seconds. When they go up, they go up!
Yes, I know there is Llthium Iron and Lithium. I have a Shorie in my one bike that is now 12 years old. It became not strong enough for a higher compression bike at about 5-6 years old that I bought it for. I now have it in another bike where it still has enough power to crank it. They do not like cold and are a real PITA when they are too cold to function. Around 45° was my experience.
I get 6-7+ years out of good Yuasa batteries, so that is what I'm still with. Just my opinion, take it for what you want of it.
