PLEASE HELP ASAP FLH CLUTCH
Old Dec 2, 2005 | 06:57 PM
djk's Avatar
djk
Stage III
Default PLEASE HELP ASAP FLH CLUTCH
OK, I ASKED THE OTHER DAY ABOUT THE CLUTCH ON MY 78" FLH IS IT A WET OR DRY CLUTCH. I WAS TOLD THAT IT IS A WET CLUTCH. SO I REPAIRED IT AS IF IT WAS WET AND IT IS STILL SLIPPING, HOW CAN YOU TELL IF IT IS A WET OR DRY AND DOES ANYONE HAVE ANY SUGGETIONS WHAT COULD BE WRONG?
Old Dec 2, 2005 | 08:23 PM
pococj's Avatar
pococj
Default RE: PLEASE HELP ASAP FLH CLUTCH
Thing is on a bike this old is that the clutch plates may be wet plates, dry plates, or wet-or-dry plates. Most everyone I know, me included, always replaced the stock plates with Barnett wet-or-dry plates. And most everyone I rode with disconnected the oil lines to the primary and then put in some ATF to lube the chain. But who knows what you have? If you've adjusted the clutch properly and it is still slipping, it is probably worn out. Get some Barnett wet-or-dry plates, get rid of the oil lines to the primary and seal it off. When you have the new plates installed and adjusted according your service manual, add Ford ATF to the primary. Leave the bike on the side stand, and add enough ATF to come to the bottom of the clutch basket as seen through the derby cover.
The ATF will lube the chain quite well, and works better than regular motor oil on the plates. And added benefit is now the primary oil, polluted with clutch plate debris, won't recirculate through your engine.
Old Dec 2, 2005 | 08:28 PM
Wolhar's Avatar
Wolhar
Skip, you ever thought to put all that knowledge in a book? If you do, or have, autograph a copy and send it to me COD.
Old Dec 2, 2005 | 10:53 PM
pococj's Avatar
pococj
Sounds like work to me!
Old Dec 3, 2005 | 05:08 AM
mikeisglidn's Avatar
mikeisglidn
ill take one too just as long as you dont mention ya hates chrome!
Sibs
Custom Models
Jun 13, 2011 08:41 PM
Lou G
Mar 13, 2011 04:02 PM
shovelheadsteve
Shovelhead
Jul 7, 2008 01:59 PM
hotscooter
Oct 31, 2007 09:35 AM
Timboto
Shovelhead
Aug 28, 2007 10:13 PM
