How to??...stop clutch lever from vibrating
Old 09-25-2007, 03:40 PM
sundancewind's Avatar
sundancewind
sundancewind is offline
Default How to??...stop clutch lever from vibrating
I was curious to know if others have their clutch lever vibrate...it makes a damn awfull noise!
I compared thefront brakelever which is nice and tight and noticed a bit of play around the lock washer of the pin that holds the clutch lever in place.
I was thinking I could add a second washer to make it snug ?
any thoughts
thanks
Fred
Old 09-25-2007, 04:25 PM
DocHarley's Avatar
DocHarley
DocHarley is offline
Default RE: How to??...stop clutch lever from vibrating
When you release your clutch lever does it spring back all the way? There should be a little tension on the handlewhen its not being used, if not you may need to have you clutch cable adjusted by somebody who knows what they are doing. If thats not the cause then I see no reason why a small washer would not solve your problem.
Old 09-25-2007, 04:47 PM
screwball's Avatar
screwball
screwball is offline
Ride with a finger resting on the lever
Old 09-25-2007, 05:13 PM
electaRICK's Avatar
electaRICK
electaRICK is offline
there are new levers out there that are made to not vibrate... try motorsport.com
Old 09-25-2007, 05:19 PM
st john's Avatar
st john
st john is offline
Go with Docharley, very minor adjustment and you should be able to
take the play out without making a clutch adjustment, Just do one thread
turn at a time till the play is gone this will not adjust the clutch plate. The
adjustment is the cable adjuster down by the regulator/frame under the
rubber boot. need two open end wrenches.
Saint
Old 09-25-2007, 08:50 PM
Flatlander's Avatar
Flatlander
Flatlander is offline
My clutch lever vibrates also and like st. john said the cable needs adjusted. I asked my stealer about it and they said it would take five minutes and is covered under warranty. Now I just gotta drag my *** to the dealer.
Jackpoticorn
10-07-2016 10:29 AM
Kwest88
05-18-2015 01:00 PM
WG2011
03-31-2015 09:24 PM
Bankrupt
Exhaust System Topics
04-11-2011 05:36 PM
tennessee streetglide
08-16-2009 07:22 AM
Quick Reply: How to??...stop clutch lever from vibrating
