??? on adjusting clutch lever
Old Aug 14, 2009 | 12:09 PM
tennessee streetglide's Avatar
Default ??? on adjusting clutch lever
My clutch lever is rattling and driving me crazy. Could somebody tell me how to get this adjusted.Do I need to adjust it on the frame?
Old Aug 14, 2009 | 01:07 PM
Anybody got any helpfull information
Old Aug 14, 2009 | 01:12 PM
ks-waterbug's Avatar
ks-waterbug
I was able to adjust the free play out of my clutch underneath the black rubber booty, but not really sure about the lever itself. Been a while since I did one but seems to me that there was one fastener that held this in place...
Old Aug 14, 2009 | 01:15 PM
gary_montague's Avatar
gary_montague
I think there is a spring washer that may be missing in action.
Old Aug 14, 2009 | 01:16 PM
SurlyBear's Avatar
SurlyBear
6th Gear
On my 09 SG the clutch lever simply rattles. I put the thing to the tight side of factory spec (1/16" free play in the cable at the clutch perch) and it still rattles. I've noticed that it is the lever vibrating on the pivot pin and this would not be helped by a tighter cable. Also, you run the risk of putting constant pressure on the clutch pack itself which may lead to accelerated wear and slipping...
Neckball's Avatar
Neckball
There is an anti rattle clip that is attached to the bottom side of the lever. It wears. It's a half moon looking piece of plastic, simple to replace. Get one.
Old Aug 14, 2009 | 01:22 PM
BlackFLHR's Avatar
BlackFLHR
Originally Posted by ks-waterbug
I was able to ... play ... underneath the black rubber booty, but not really sure about the lever itself. Been a while since I did one but seems to me that there was one fastener that held this in place...
Whoaaa!!!!!!
Old Aug 14, 2009 | 09:01 PM
Thanks for the info
Old Aug 14, 2009 | 10:55 PM
I checked and the clip is still in place sprayed the top and bottom with w-d40 and it helped alot
Old Aug 15, 2009 | 02:56 PM
emwolb's Avatar
emwolb
neckball is right, they still use that anti rattle clip. i'm not sure if they still use a nylon bushing in the lever itself for the pin to pivot on or not. if so, that may be worn out. both are very simple to replace.
