Thunder Max.......
Old Dec 2, 2007 | 07:14 AM
dynaguy's Avatar
dynaguy
Default Thunder Max.......
Anybody running this?From what i have read it sounds pretty good. If i am reading right it will program it self as you ride.If you are running it how is it. Sounds like it better than a PC111. [sm=biker.gif]
Old Dec 2, 2007 | 07:39 AM
biz44's Avatar
biz44
Default RE: Thunder Max.......
Yes the T-max auto tune is better than the PCIII, but it costs quite a bit more. You need to have a 02 bung installed in each head pipe for the T-Max so it can monitor the current f/a ratio and change it on the fly. It will also automatically compensate for any other mod's you do down the line. It uses what it called a open loop system along with wide band 02 sensors to optimize the f/a mix foe all conditions. I am not 100% sure if it will also change ignition timing at all or raise the rev limiter setting, but from what I understand it is one of the best systems on the market right now. I am not too sure if they have the unit ready for the 2008 bikes yet, but I am sure it will not be too long if they dont.
I am not using it....I decided to go with the SERT on both of my bikes, but if I was unsatisfied with the SERT, I would buy the T-Max with no reservations at all.
Old Dec 2, 2007 | 08:10 AM
wadejesu's Avatar
wadejesu
I had a PCIII and ditched it for the Thundermax, It is far superior. It auto adjusts A/F. You can change timing but it is a software change, simple to do.
Old Dec 2, 2007 | 10:17 AM
Bigbird07's Avatar
Bigbird07
thunder max rocks. yes cost more, you only get what you pay for!!!! go thundermax dude
Old Dec 2, 2007 | 11:50 AM
Mickeys Customs's Avatar
Mickeys Customs
I also had a PCIII and switched out to the T-Max. The T-Max cost much more but will worth it in my opinion. Sice installed the bike pulls much harder and better throttle response with my mods. I have only put around 100 miles if thaton her with the T-Max and I'm told she will run much better as I add some more miles.
Old Dec 2, 2007 | 12:00 PM
Tinkermc's Avatar
Tinkermc
I have t-max and long ago I forgot about what it cost. What it does is fantastic and I can keep adding stuff or upgrades and it catches on fast.
Old Dec 2, 2007 | 12:10 PM
Bigbird07's Avatar
Bigbird07
Well said Tinkermc,yes upgrades, it never grows old thundermax auto tune
Old Dec 2, 2007 | 12:22 PM
electaRICK's Avatar
electaRICK
so... this aint about mad max and the thunder dome??
cause thats the way I see our nearby future!!!!!
I bet Kolni,, will be the one flyin in that ultralite! lol
Old Dec 2, 2007 | 03:31 PM
sugarbear's Avatar
sugarbear
The thunder max is great and comparing cost add something else and a dyno tune and you are there. If you change anythinbg you are way ahead. jmo
Old Dec 2, 2007 | 06:32 PM
cardboard's Avatar
cardboard
Had a TM on my 07 WG for about a year. Was the best thing I ever did for it. Traded it for a 07 touring with DBW.
Now HD changed the plug for the ECM and the programming is different.
Sittin and waiting for TM to come out with a fix or update for it and I will put it on my new 08 touring bike. They claimed it will be out after the 1st of the year.
rockon
May 12, 2014 09:50 PM
dbrillha
Oct 18, 2008 11:59 AM
danike
Dec 13, 2007 06:14 PM
Ace07FXDL
Jun 8, 2007 01:10 PM
Skip
Sep 21, 2006 12:11 PM
