Coil relocation on late model softails?
Old Dec 24, 2007 | 04:25 PM
4merRacer's Avatar
4merRacer
Default Coil relocation on late model softails?
I did a search last night trying to find a relocation kit for the coil. I'd like to find one of the dagger/spear (?) shaped coil covers/motor mountthat are commonly found for older model engines and that would allow the relocation of the coil. Correct me if I'm wrong but I'll have to cut the coil bracket off once I do this, right?
Something similar to this would be ideal:
http://cgi.ebay.com/ebaymotors/BILLE...em230205982931
Thanks again...always great info around here!!
Old Dec 24, 2007 | 06:46 PM
sonar_chris's Avatar
sonar_chris
Default RE: Coil relocation on late model softails?
Well, I dont think you would have to cut off the coil bracket, but to make it look better you probably would want to. Only problem is the late model coils are a one piece unit. The bracket you have linked is for a 2 coil system. Now I dont know if you can change from a one coil to a two coil system on a TC, but that may be something to think about as well. I also am not aware of a mount like that for just one large coil.
Chris
Old Dec 24, 2007 | 07:13 PM
4merRacer's Avatar
4merRacer
Thanks for the scoop, Chris. I'll check with the techs about switching and the ramifications (if any) of doing so.
BigBlue48
Jun 16, 2016 10:00 AM
bura0031
Aug 7, 2013 11:20 AM
meat stick
Jan 14, 2013 02:01 PM
Curtis87
Aug 19, 2011 07:02 PM
motordrum
Apr 11, 2009 08:25 PM
