Rear axle help
Old Jan 1, 2008 | 06:04 PM
retep2281's Avatar
retep2281
Default Rear axle help
Alright i need some help here. Im in the process of doing the heartland 250 kit and today as i was flying throught the reassembly of the swing arm to retro fit everything i ran into a problem. The wheels i have, have the 1" axle bearings and my 03 uses the 3/4" i beleive. Does anyone know how i can get a sleeve or a bushing or something i can use so the axle will fit snug. Thanks in advance.
Old Jan 1, 2008 | 07:37 PM
cadillac's Avatar
cadillac
Default RE: Rear axle help
Im not positive but I think you can have the old bearing pressed out and a new one pressed in.
bob
Old Jan 1, 2008 | 09:05 PM
FastHarley's Avatar
FastHarley
Former Sponsor
A 3/4" wheel may not have the ability to use a 1" axle because the axle bushing will not fit inside. You must check out the inside of the wheel yourself to make sure. This is what you will find in a FL. If your hub is the same the same message is yours [HERE]
Old Jan 2, 2008 | 05:17 AM
cHarley's Avatar
cHarley
You should be able to replace the 1" bearings with a set of 3/4". You don't say if you are using a HD wheel or something else. HD sells kits that include the bearings and sleeve that will do the job.
Old Jan 2, 2008 | 08:36 AM
retep2281's Avatar
retep2281
Old Jan 3, 2008 | 10:01 PM
retep2281's Avatar
retep2281
Called My local dealer and took the wheel in 114 including parts, since i know a bunch of the guys there they only billed me for 30mins of labor instead of the 1.5 like normal to remove and replace bearings. got it done now i just need the right spacers. Thanks for the help guys.
johnod
EVO
20
Feb 19, 2015 03:32 PM
paulx24x
Apr 10, 2013 06:22 AM
limj23
Wheels/Tires
Jun 7, 2010 11:33 AM
DarkManC
Sep 16, 2009 02:55 PM
Boogity_Boy
Sep 2, 2006 01:30 AM
