Harbor Freight Jack
Old Jan 26, 2008 | 09:54 PM
Dc78's Avatar
Dc78
Default RE: Harbor Freight Jack
Cut three peices of 3/4" plywood one under each tire one under jiffy stand. What I had to do on the Sears red lift. This is on a Deluxe.
rex0350's Avatar
rex0350
This one measures5" with itfully down, no spacers or anything.
Sounds like the 2x4 ramp is my only option.I was just under the assumption that this particular jackwould fit without any help. Nobig deal really.
Overallit appears to be a good, sturdy jack.The only concern I have is the attachment point for the jack ram,it's pretty flimsy looking.I mightend up replacing that myself and make itstronger.
Thanks for the help
Old Jan 26, 2008 | 11:03 PM
oldfartjc's Avatar
oldfartjc
ORIGINAL: themensh
Did you remove the 'adapters'? On my yellow jack, there 'lifts' on it........you remove
the lifts/adapters and that allows you to put the jack under lower bikes.
Check and see if yours have them.
chuck
He doesn't have the Sears yellow jack which has those adapters.
Old Jan 26, 2008 | 11:54 PM
Harley03joe's Avatar
Harley03joe
My Jack
This versatile Motorcycle Jack made by Torin is the answer to all your motorcycle/ATV lifting needs. Lift any small vehicle from your bike to an ATV or even a snowmobile. It has a 1500-pound capacity, including 6 locking positions and 2 locking swivel casters, bottle jacks, and pulling bar. Great for storage, cleaning or working on your bike.
[ul][*]
Model: T64415[/align] [*]
Lifts: Motorcycles, ATVs[/align] [*]
1500-pound capacity[/align] [*]
6 locking positions[/align] [*]
2 locking swivel caster[/align] [*]
Bottle jack[/align] [*]
Pulling bar [/align] [*]
Height (min): 5.12"[/align] [*]
Height (max): 17.12"[/align] [*]
Weight: 56.88 lbs.[/align][/ul]
My 2003 Softtail Heritage Classic Stats
Dry weight:
335.0 kg (738.5 pounds)
Seat height:
697 mm (27.4 inches) If adjustable, lowest setting.
Overall length:
2,391 mm (94.1 inches)
Ground clearance:
129 mm (5.1 inches)
Wheelbase:
1,630 mm (64.2 inches
[IMG]local://upfiles/44170/625A5E01495244D08BF1E30ADD79E35D.jpg[/IMG]
Old Jan 27, 2008 | 07:40 AM
1flhtk4me's Avatar
1flhtk4me
ORIGINAL: rex0350
What am I missing here? Suggestions?
Add a air suspension!
Old Jan 27, 2008 | 08:34 AM
itsaw0rkinpr0gre$$'s Avatar
itsaw0rkinpr0gre$$
"Seeker of Freedom"
ORIGINAL: Harley03joe
My Jack
[ul][*]
Dry weight:
Seat height:
Overall length:
Ground clearance:
129 mm (5.1 inches)
Wheelbase:
Umm 5.12" is taller than 5.1" of clearance, that's cutting it close don't you think.
Old Jan 27, 2008 | 08:52 AM
candyx's Avatar
candyx
Sounds like you should of went for the pitbull jack,it needs no adapters,ramps or peices of plywood.You just slide under your bike and lift her up safely and scurely.Ifsomeone wanted to buy a boat anchor , i would imagine they would call a company with the name of HARBOR FREIGHT.It just sounds like they would make a good boat anchor.
Old Jan 27, 2008 | 08:53 AM
dexterdave's Avatar
dexterdave
I have the same Harbor Freight jack. It just barely slides under my '04 1200C and is kind of wobbly when it gets off the ground. When I use it, i just barley get the wheels off the ground and keep the front tire in a Condor/PitStop.
Old Jan 27, 2008 | 11:56 AM
bcox's Avatar
bcox
ORIGINAL: rex0350
Thanks for the help
Take it back and get a J and S. Nothin flimsy about them . . . and no adapters or plywood ramps.
Old Jan 27, 2008 | 02:08 PM
Bumm's Avatar
Bumm
The guy obvioulsy bought the Harbor Freight jack because it was cheap...just like the 2 that I have. Roll yourfront or rear tireonto a short piece of 2X6. it will give you the height you need to clear the jack under your bike. It is a little inconvience but saves a bunch of bucks!
Good Luck!
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
