Help Misprint?
Old Mar 13, 2008 | 03:50 PM
singlepin's Avatar
singlepin
Default Help Misprint?
On page 2-88 of the Service Manual. " Tighten lower shock bolt to 30-45 ft lbs. Tighten top shock bolt to 33-35 ft lbs." This can't be right! That is barely tight at all. What is the right setting on the torque wrench?
This is on an 07 Ultra. Thanks. John
Old Mar 13, 2008 | 04:00 PM
Pat's Avatar
Pat
Default RE: Help Misprint?
Are you sure you are not using a wrench calibrated for inch-lbs instead of ft-lbs? I've made that mistake before.
Old Mar 13, 2008 | 04:15 PM
singlepin's Avatar
singlepin
It is a new torque wrench, but even if I was setting the wrench wrong--the listing still says 30-45 ft lbs. That is not much pressure.
Old Mar 13, 2008 | 04:39 PM
FatTony's Avatar
FatTony
Just looked in the '08 Sportster manual and it says 45-50 ft. lbs.
Old Mar 13, 2008 | 04:43 PM
Lincoln33's Avatar
Lincoln33
Hey single I have an 01 RK and my manual says lower shock bolt 35-40 ft lbs and upper shock mounting bolt 33-35 ft lbs. I think Pat was saying to make sure your using a ft lbs torque wrench and not an inch lbs torque wrench.
Old Mar 13, 2008 | 04:50 PM
Jim Dawson's Avatar
Jim Dawson
ORIGINAL: singlepin
That isa lot of torque on a bolt that size. You only tighten the muffler clamp bolts to 65 ft lbs and tht is a lot larger bolt.
Old Mar 13, 2008 | 05:06 PM
lecomte38's Avatar
lecomte38
JUST TIGHTEN IT !!!! Wrap up that new torque wrench and put it away. Do you really believe that the HD service techs or the assembly line workers are "torquing every nut and screw on the bike? critical internal engine and transmission componments require proper torquing. The only other three torques values you need are : snug, tight and MF tight. Make the shock mounts tight, as in not as tight as the rear axle (MFtight) but tighter then the seat mount screw (snug).
Old Mar 13, 2008 | 05:16 PM
skltr's Avatar
skltr
[sm=exactly.gif] [sm=funnypostabove.gif]
Old Mar 13, 2008 | 05:23 PM
carlo's Avatar
carlo
You sure your not using a inch lb wrench. The wrenches look all most the same.
Old Mar 13, 2008 | 07:34 PM
singlepin's Avatar
singlepin
Hey lecomte38; I agree with ya. I just tightened it really snug. Not really worried about it; was just wondering if it was right cause it seems pretty light to me. Figured it was a good chance to try outthe new wrench. Thanks guys for the responses.
