turn signal question
Old Mar 16, 2008 | 05:11 PM
lwszabo's Avatar
lwszabo
Default turn signal question
I removed my back turn signals from my 1995 Springer softail a week ago, and lost the ability to have front ones blink. I also lost the ability for the brake light to light up when i used the front brake (rear brake still worked right.) Today I put on new drag bars, and took off the front turn signals, and now the brake light is very bright, and the housing seemed to get hotter than normal. I plan on small turn signals in the future, but now I dont want to burn up my wiring. Does all this sound normal ,I am thinking the electrical system needs all the signals for everything to work corect, what do you think???????
Old Mar 16, 2008 | 05:21 PM
electaRICK's Avatar
electaRICK
Default RE: turn signal question
I THINK YOU SHOULD HAVE LEFT WELL ENUFF ALONE!!!!!!! []
Old Mar 16, 2008 | 05:23 PM
prc1333's Avatar
prc1333
Either put back to original or use some resistors to counter the loss of rear signals.
Old Mar 16, 2008 | 06:07 PM
motorcycle's Avatar
motorcycle
YOU WILL HAVE TO INSTALL A BLINKER RESISTOR, THEY ARE CHEAP, AND EASY, TO PUT IN. I REMOVED MY FRONT BLINKERS, DID THE SAME THING. SPRING IS CLOSE!
Old Mar 16, 2008 | 06:41 PM
zukeeper's Avatar
zukeeper
get a load equalizer ( like badlands) and all will be fine again. Your system needs a set amount of current draw and the equalizer will provide that.
Old Mar 16, 2008 | 06:51 PM
jad's Avatar
jad
Yep, you need a resistor in the circuit. If you have an alarm you’re going to have troubles there also. A friend of mine installed the small LED lights and had to do the same thing.
[IMG]local://upfiles/47469/6EDADB24A4924512A616230B5FD86ECF.jpg[/IMG]
saltlick
Sep 14, 2016 11:34 AM
jsl6v8
Electrical/Lighting/Alarm
Oct 25, 2015 01:35 PM
Swedish Night Train
May 18, 2008 02:59 AM
wetjet
Aug 4, 2006 05:16 PM
Beefcake
Mar 6, 2006 07:31 PM
