Brake Drag
Old Apr 9, 2008 | 10:08 PM
ultrastreet's Avatar
ultrastreet
5th Gear
Default Brake Drag
Well this is my first post and introduction to HD Forum. I have an '07 Ultra Classic that I stripped down and re-painted. As a result I removed the two front brake calipers rather easy, no big deal, and supported them properly until I re-installed them. Well had a brain fart andIpulled the brake leverwhile moving the bike while the brake calipers were still off. So...you guessed it I went to put them back on therotors and the pads were comprised.There is alot of pad left and I was able to back them off and fit them onto the rotors.I reassembled everything and with the bike still on lift I attempted to rotate the front wheel. I found that there is quit a bit of drag, got about 1/2 rotation. No I did notdo this before I took the brakes off so I have to reference to how freely the front wheel should spin.
My question is, isthis normal or how freely should this rotate. If not good any ideas on how to remedy.
Signed......."Momentary Brain Fart"
Old Apr 9, 2008 | 10:15 PM
ss377's Avatar
ss377
Default RE: Brake Drag
Normal. The pads will ride against the rotor all the time. If you never touched the front brake, they would still be warm to the touch.
Old Apr 9, 2008 | 10:32 PM
ultrastreet
5th Gear
Thanks for the fast reply, makes me feel alittle better...
"Rubber Side Down --- Louder the Better"
Old Apr 9, 2008 | 10:58 PM
Arizona Flash's Avatar
Arizona Flash
ORIGINAL: ss377
+1. Harley brakes surprisingly drag a lot in normal operation. Proof is in the ride. If you can't tell any difference now than before, your OK. If a difference is noticed, you have to dig some. Maybe a piston is hanging up some.
Old Apr 10, 2008 | 12:25 AM
skltr's Avatar
skltr
Since the caliperswere actuated without the rotor in place, did you bleed the calipers to remove any potential air in the system?
Old Apr 11, 2008 | 04:01 PM
wdg's Avatar
wdg
some drag is normal
PPearl
Apr 20, 2025 05:04 AM
TracerBullet
Wheels/Tires
Oct 31, 2013 12:40 PM
Voelser
Jul 11, 2012 06:35 AM
hogdvr
Aug 31, 2008 06:17 PM
RoadK69
Apr 24, 2007 10:21 PM
