Drain plug... O-rings..................................
Old Apr 30, 2008 | 04:58 PM
electaRICK's Avatar
electaRICK
Default Drain plug... O-rings..................................
WHO'S fkn Idea.. WAS THAT??????
to loose they leak..... to tight they leak!!!!!
what happened to the hunting permits for retards??
Old Apr 30, 2008 | 04:59 PM
hdpearson13's Avatar
hdpearson13
Default RE: Drain plug... O-rings..................................
they still issue them.
Old Apr 30, 2008 | 05:01 PM
electaRICK's Avatar
electaRICK
yea,, some turd brain brought em back on the 08's!
Old Apr 30, 2008 | 05:55 PM
GGC's Avatar
GGC
Let's see,, You had trouble with Your 07, now Your 08!,,,,Might just be You!!!!! J/K!
Old Apr 30, 2008 | 05:59 PM
rbabos's Avatar
rbabos
ORIGINAL: electaRICK
Can't imagine how an o ring could cause you greef unless you are putting then in dry. That will tear them on install and leak. Mind you they will tear when you remove the plug because the surfaces stick and are drywhich is why they need to be replaced. I'll take an o ring any day over those stupid pipe plugs. That's steam engine technology.
Ron
Old Apr 30, 2008 | 06:03 PM
ezriderpgh's Avatar
ezriderpgh
the holes are concaved so the o-ring isn't actually getting smashed between the plug and the pan. use a bit of teflon tape too and just snug.
Old Apr 30, 2008 | 06:33 PM
rbabos's Avatar
rbabos
Boo, Hiss on the teflon tape. Loctite white paste with teflon much easier to use and won't fill up the innards with teflon stringy ****. Correct on the o ring pocket to control amount the ring can be compressed, assuming the correct cross section is used.
Ron
Old Apr 30, 2008 | 06:42 PM
Lincoln33's Avatar
Lincoln33
I replace the o-ring every time I change the fluids and torque to spec. So far I haven't had a problem with leaking.
Old Apr 30, 2008 | 06:48 PM
jandlcars's Avatar
jandlcars
From: NOMAD Milton FL Now Originaly From San Rafael CA
Hay Rick off issue ? where does all the unused electricity go
Old Apr 30, 2008 | 06:49 PM
Mandog's Avatar
Mandog
ORIGINAL: Lincoln33
+1
