Model Name Acronyms?
Old May 7, 2008 | 02:15 PM
BigMike80's Avatar
BigMike80
1st Gear
Default Model Name Acronyms?
Im a newb to Harleys and everytime someone lists a bike by the acronym (XL, FXSTF, FXD, etc) I have to go look up which bike they are talking about. Is there a post here already that explains the rhyme and reason behind these initials?
I tried to search but couldnt find an answer...sorry if this is a common post here.
Thanks
Mike
Old May 7, 2008 | 02:37 PM
throttlejunkie's Avatar
throttlejunkie
Default RE: Model Name Acronyms?
Hey BIGMIKE,
this doesn't explain it, but it does list them if you need a quick reference chart..
Dave
Old May 7, 2008 | 02:38 PM
IRideMineEverywhere's Avatar
IRideMineEverywhere
Ya know, WAAAAAYYY back in the '70's a couple of friends of mine came up with neat little meanings for all them little letters that Harley gives their bikes.... Needless to say, everything that started with F was F'ing..... I don't believe there is actually a definition for them but I would also like to know....
Old May 7, 2008 | 07:19 PM
supernova's Avatar
supernova
This was the best I could find:
Model designations
Harley model designations are a sequence of letters and numbers, combined in limited ways. The sequences can be long, as in the 2006 model designation FLHTCUSE. The first letter may be one of the following:
E, J, K ('50s small twin),
F, U, V (Big Twin),
D, G, R, W (Small Twin),
X (Sportster), or V (VRSC)
Letters are appended singly or in pairs, as follows: B (Belt Drive), C (Classic or Custom), D (Dyna Glide), DG (Disk Glide), E (Electric start), F (Fat Boy (1990-present) or Foot-shift (1972 and prior)), H (High compression), L (Hydra Glide forks), LR (Low Rider), P (Police), R (Race or Rubber-mount), S (Sport, Springer, or Standard), SB (Single belt final drive), ST (Softail), T (Touring), WG (Wide Glide), I (Fuel injection), SE (Screamin’ Eagle), U (Ultra) Custom Vehicle Operations models can also have a number (2,3,4) added. Note that these conventions for model designations are broken regularly by the company.
Current model designations [ul][*]Sportster With the exception of the street-going XR1000 of the 1980s, all Sportsters made for street use have the prefix XL in their model designation. For the Sportster Evolution engines used since the mid 1980s, there have been two sizes of Sportster Evolution engine. Motorcycles with the smaller engine are designated XL883, while those with the larger engine were initially designated XL1100. When the size of the larger engine was increased from 1,100 cc to 1,200 cc, the designation was changed from XL1100 to XL1200. Subsequent letters in the designation refer to model variations within the sportster range, eg. the XL883C refers to an 883 cc Sportster with cruiser or custom styling, while the XL1200S designates the now-discontinued 1200 Sportster Sport.[*]Dyna models utilize the big-twin engine (F), small-diameter telescopic forks similar to those used on the Sportster (X), and the Dyna chassis (D). Therefore, all Dyna models have designations that begin with FXD, eg. FXDWG (Wide Glide) and FXDL (Low Rider).[*]Softail models utilize the big-twin engine (F) and the Softail chassis (ST). [ul][*]Softail models that use small-diameter telescopic forks similar to those used on the Sportster (X) have designations that begin with FXST, eg. FXSTB (Night Train), FXSTD (Deuce) and FXSTS (Standard).[*]Softail models that use large-diameter telescopic forks similar to those used on the touring bikes (L) have designations beginning with FLST, e.g. FLSTF (Fat Boy), FLSTC (Heritage Softail Classic) and FLSTN (Softail Deluxe N is for Nostalgic.)[*]Softail models that use Springer forks with a 21-inch (530mm) wheel have designations that begin with FXSTS eg. FXSTS (Springer Softail) and FXSTSB (Bad Boy).[*]Softail models that use Springer forks with a 16-inch (410mm) wheel have designations that begin with FLSTS eg.FLSTSC (Springer Classic)[/ul][*]Touring models use Big-Twin engines and large-diameter telescopic forks. All Touring designations begin with the letters FL, eg. FLHR (Road King) and FLTR (Road Glide)[*]Revolution models utilize the Revolution engine (VR), and the street versions are designated Street Custom (SC). After the VRSC- prefix common to all street Revolution bikes, the next letter denotes the model, either A (base V-Rod), B (discontinued), D (Night Rod), R (Street Rod), SE (CVO Special Edition), or X. Further differentiation within models are made with an additional letter, e.g. VRSCDX denotes the Night Rod Special. [ul][*]The factory drag bike, the VRXSE Destroyer, uses X instead of SC to denote a non-street bike and SE to denote a CVO Special Edition[/ul] [/ul]
Old May 7, 2008 | 07:45 PM
harleydude68's Avatar
harleydude68
ORIGINAL: supernova
Model designations
F, U, V (Big Twin),
[ul][*]The factory drag bike, the VRXSE Destroyer, uses X instead of SC to denote a non-street bike and SE to denote a CVO Special Edition[/ul][/ul]
And there you have it!
ylwf3vr
Sep 16, 2015 11:12 PM
Blowzo
Oct 5, 2012 08:00 AM
1badbagger
Apr 20, 2011 09:21 AM
OldFenderGuy
May 2, 2007 06:54 PM
pilot1996
General Topics/Tech Tips
Jun 19, 2005 03:01 PM
