My 02 88" is basically stock and hates anything but 91+. It just will not idle, hesitates, gets lousy mileage, etc. (like it is doing today!!)
Oddly enough, my 92 80" has had cams and a bunch of other stuff, yet it will run fine on garbage - but runs better the higherthe octane. Even on the cheapest swill, it gets over 50 mpg.
I usually run mid-grade, which here is 87. Regular is 85 and premium is 91. Course, I am at 6000ft so compression ratio is somewhat less than factory. Probably close to 8.2 to 1 CR, so less octane needed. Also, lower octane fuels , IIRC, have longer hydrocarbon chained molecules, so more energy stored in the extra Carbon-to-Carbon bonds. You will get better mileage out of a lower octane fuel. Just make sure you don't get any pinging. You will need higher octane, if you are in a situation where the motor is going to get hot, to resist pinging.
Thanks all. I put in 87 last night and have riden about 80 miles, 60 this afternoon coming home, riding about an hour, no pinging, no hesitation, no problems with idle and the motor seemed to be running the same temps.
So who knows, ayway I will proberly run the midgrade as long as its not pinging.
H-D owners manuel says use 91 octane or higher. Why bother with lower grades? The MoCo knows best what octane rating should be used with their engines. If you are not getting any knocking or pinging I guess that's good, but maybe over the long haul you may be doing harm to the engine. For the few pennies difference between midgrade and premium I would not bother myself. Just my .02
Much of what makes it into the owner's manual is there to protect the MoCo, not you and your machine. All other things being equal, you will get more horsepower andmore efficiency from a lower octane fuel, absent predetonation. Getting more power form higher octane is one of the most widely misunderstood concepts in modern machinery! If you are running high compression, high heat or other conditions that warrant high octane, then you are constrained. Unless I am at en event and know that I am going to begetting stuck in traffic with high ambient temperatures, I run regular and have had no problems whatsoever. I enjoy more power and lower operating costs. Recommending higher octane in lower compression engines is a safe way for the manufacturer to avoid problems with premature detonation.
The example posted above with higher mileage is not surprising at all - in fact, it is to be expected.
I have expressed whatI do on my bike. Don't try this at home - YMMV.
That is interesting stuff. My riding buddy switched from 91 to 89 octane in his Kawasaki Nomad, and his gas mileage has come up. He was getting just under 40 on 91 octane but is getting 41-42 on the 89. Hmmm!
with that kind of thinking i assume you ran only hd dino oil up until a few years ago and now you only run syn 3 because that is what the moco reccommends?
what i heard on the tv theother night. is that the higher octane causes the enine to run cooler. how much who knows? as for the milage differances, is your bike ever consistant with say, 40 mpg everytime you fill it up? for me it depends on how i drive, traffic that week. it cant ever me consistant so to say that you put in 87 or 89 octane and it made a 1 to 2 mile differance. did it really make a differnance? exept in the wallet
