1985FX 1340 been away a year. Changed oil filter kicked to oil top end. Getting allot of crank case oil pushing up tube into air box.
Any ideas motor heads?
Not a ton of info, but judging by your post and dates, I am guessing it is 'wet sumped'. Oil from tank has drained into crankcase. Will either blow it into air box or on the ground (if breather hose disconnected) until it gets 'dried out' (oil is pumped back to tank) Not uncommon for EVO's. This is going on your post about it sitting a year. Can wet sump faster than that, but if you haven't started it in a LONG time, this is my first guess.
+1 and it's not really a problem once you clean up the mess, lmao!
