Winter Storage?
Old Mar 15, 2006 | 08:09 PM
RandyD123's Avatar
RandyD123
Default Winter Storage?
My new 06 SG will be in cold storage next winter. I most likely will remove the battery and use a battery tender to keep it fresh.
When I re-install the battery will I have to re-program the alarm?
Will I have to use that long drawn out procedure listed in the DIY?
I see that says for 2003 bikes is it the same for the 06's?
Will the ECM need to be reprogramed?
Old Mar 15, 2006 | 08:24 PM
AK_Hog_Herder's Avatar
AK_Hog_Herder
Default RE: Winter Storage?
There is a short procedure you use to reset the alarm after battery disconnection. It is in your owners manual and takes a few minutes.
No programming will be lost so you don't have to go thru the complete reprogram/relearn procedure again.
Old Mar 15, 2006 | 09:03 PM
stile45's Avatar
stile45
RandyD123 , why dont you just install a battery lead on the battery terminals and hook up the battery tender in the bike? It wuold be much easier that removing the battery.
Old Mar 15, 2006 | 09:19 PM
RandyD123's Avatar
RandyD123
Takes way more than a few minutes. More like 30 plus according to the info in the DIY section.
ORIGINAL: AK_Hog_Herder
Old Mar 15, 2006 | 09:20 PM
RandyD123's Avatar
RandyD123
Ya I'm thinking of doing that.
ORIGINAL: stile45
Old Mar 15, 2006 | 09:23 PM
gumby62's Avatar
gumby62
ORIGINAL: stile45
This is what I would recommend also.
Old Mar 15, 2006 | 10:46 PM
AK_Hog_Herder
ORIGINAL: RandyD123
No, you are looking at the wrong one. The 30 minute one is the password learn and only has to be done once after you install the TSSM.
To reset it after a battery disconnect is just a few flips of the ign switch and the turn signals. Look in your owners manual
user 62642348
Jan 19, 2018 01:28 PM
slowspeeder
General Topics/Tech Tips
15
Jul 26, 2016 12:34 PM
Yul B. Nekst
EVO
22
Aug 26, 2013 07:41 PM
weasel
Dec 1, 2007 06:14 PM
toadmanor
17
Dec 8, 2005 02:00 AM
