Scratch on W/S
Old Aug 8, 2008 | 07:09 PM
Guess's Avatar
Guess
Stage III
Default Scratch on W/S
Anybody have a suggestion on the best way to get a scratch cleaned off a lexon windshield ?
Thx
Old Aug 8, 2008 | 07:31 PM
barjbar's Avatar
barjbar
www.novuspolish.com
I don't know if it works, just saw it advertised.
Old Aug 8, 2008 | 07:44 PM
John TN's Avatar
John TN
Novous is very good stuff,, there's different grades for polishing, cleaning and getting out the scratches, great product.
Old Aug 8, 2008 | 08:26 PM
noname's Avatar
noname
I have had very good luck with 3M fine scratch remover. It goes on like wax, just buff it with a soft terry cloth, by hand for a bit, use a bit of elbow grease, then it'll set up like wax does, and wipe it off. Like I said, I've had very good results. Noname
Old Aug 8, 2008 | 08:38 PM
confederate's Avatar
confederate
Most Wanted
I used the Quixx acrylic and plexiglass scratch remover. It worked perfect. Completely removed the scratch. The kit comes with fine sandpaper for wet sanding the area and rubbing polish. You will probably need to use the sandpaper as I did, but it simply works. Depending on the depth of the scratch you may need to do it multiple times. Just follow the directions and I'm sure you will be pleased as I am. I got it at Walmart for around $8.00.
hardheaded
Detailing
11
Feb 10, 2017 08:41 PM
VTwin-Goodies
Feb 11, 2010 04:30 PM
dave8983
Apr 20, 2009 08:38 PM
maltezebluez96
Mar 15, 2007 01:21 AM
Wampuscat
Dec 30, 2006 11:18 AM
