SE cams
Old Aug 9, 2008 | 11:18 AM
carpetride's Avatar
carpetride
Default SE cams
So a stage 1 plus cams is a stage 2 or is a stage 2 just changing cams? and does it really give you noticeably more power. MoCo says the cams are 50 state legal with factory mufflers, so why doesn't harley just put these cams in at the factory, or is it that the upgrade cam doesn't work well with the choked up factory motor? Seems harley could easily give these motors more power right from the factory and still meet EPA rules. I guess it's a money thing, as in how much more can they wring out of you. Do the SE 203 cams really make any difference if added to a stock stage 1 motor?
Old Aug 9, 2008 | 12:04 PM
xcelr8's Avatar
xcelr8
Stage 2 (on a 96" motor) is big jugs (103"), flat top pistons, cams, SE a/c. SE slip-ons, and ECM remap. Read all about it on the HD website in the accessories section.
Old Aug 9, 2008 | 12:22 PM
carpetride's Avatar
carpetride
OK, that def. would make a difference. I guess just adding cams to a TC88 stage 1 then is just a waste of time and money.
Old Aug 9, 2008 | 01:38 PM
xcelr8's Avatar
xcelr8
We all seem to learn the hard way. Best advice I can share with you is "leave it alone". Just give it routine maintenance per the owners manual, and the bike will give you many years of good, dependable, service.
If it ain't broke, don't fix it!
Old Aug 9, 2008 | 01:57 PM
Araba Shriner's Avatar
Araba Shriner
Here is an article about Staging Your Harley Hope it helps.
Old Aug 10, 2008 | 01:42 PM
spike95's Avatar
spike95
I would say that it might be a waste of time if all you're gonna do is put in SE203s, but if you went with a better aftermarket cam, then it could make a very large difference.
Kenita
Sep 2, 2016 12:33 PM
streetrodder
VRSC Models
Sep 21, 2011 07:06 PM
formike56
Dyna Models
Dec 24, 2008 03:48 PM
BUBBA
Jan 31, 2006 02:34 PM
Rubberduck
May 20, 2005 12:49 AM
