ATTN Admin I have info on email problems with Vbulliten V3
Old Aug 12, 2008 | 07:28 AM
John TN's Avatar
John TN
I've been getting e-mails since we started up and I'm on a web gmail,, that's some good info and I'm sure Admin will look into it. Thanks for the info!
Old Aug 12, 2008 | 08:03 AM
Mr. Lucky's Avatar
Mr. Lucky
Originally Posted by Ragtop
oh well , so much for that theory
At least you were trying to help, versus the people who just bitch and moan.
Old Aug 12, 2008 | 10:49 AM
Ragtop's Avatar
Ragtop
THANK YOU!
Sorry, my explanation may have not been too clear, but I know what works and what doesn't.
Mr Baker, if it's something wrong on the receiving end, then
why are there several other forums that have the SAME EXACT problem, ONLY after they upgraded to VBull V3?
Sounds like a Bulliten bug to me, and if you would read about
it on the web, many other sites are having the same issue.
Now there are other posts about the same topic.
I went through this same scenario last year at another forum.
Thanks for your input though.
Peace
Rags
Old Aug 12, 2008 | 11:04 AM
Ragtop's Avatar
Ragtop
Your quite welcome, I may not be able to find the exact fix
for the software, but I think I'm getting close to the problem.
I will continue to research this issue, to see if I can find more information on this problem.
cHarley has a great workaround for this, thanks for posting that, I was beginning to wonder if I am the only one here...
Peace
Rags
Old Aug 12, 2008 | 11:17 AM
cHarley's Avatar
cHarley
You're welcome.
Since I don't have access to the Vbulletin end of the connection, I can only guess at the cause of the problem, but I suspect that it may have something to do with the fact that SMTP/POP mail uses different ports than web based email does.
Old Aug 12, 2008 | 11:19 AM
Ragtop's Avatar
Ragtop
Old Aug 12, 2008 | 11:24 AM
Ragtop's Avatar
Ragtop
The problem may be in how Admin setup the email file in PHP.ini on the server.
Vbull defaults to PHP mail handling, but if that doesn't work, then try SMTP mail instead,
see below
From the Vbulletin site
"By default vB uses PHP's mail() function for all its email and uses the SMTP server specified in php.ini. If PHP and the mail server are configured correctly then email will work. You can view the details here: http://us3.php.net/mail/
To troubleshoot any email problems you will need to view the mail logs on the server to see what happened to those emails that don't work. Once vB sends it to PHP it's in the hands of the server. If you are on a shared server you may need to ask your host to look through the logs for you.
Many large service providers such as Verizon, AOL and MSN are implementing aggressive filtering. In many cases, the customers of these providers can place the email address you use for notification in their contact list and then your emails will be allowed through. If this doesn't work, you should contact the provider in question and ask to be placed on their whitelist. Some providers will charge a listing fee for this.
In addition, AOL (and possibly others) will not accept emails from domains that do not have reverse DNS setup. It's possible these emails are being placed into a spam folder or are being filtered.
The problem could also be caused by aggressive spam filters on the user's machine. In these cases their anti-spam software should be configured to allow emails from your domain name. Refer them to the documentation for the software they are using.
If all else fails you can switch to the SMTP mail option to see if this works better for you. These settings are here:
Admin CP -> vBulletin Options -> Email Options -> SMTP Email -> Yes
Then fill out the appropriate SMTP settings for your account and server.
I still think the last post on this link may be the answer, or real close to it, but then
what do I know??
http://support.jodohost.com/showthread.php?t=1691
Look at the topic on the above link/post "strange vbulletin email problem - not sending emails anymore since upgraded to 3.0.0"
If that isn't on point, then I don't know what is....
I'll keep looking though, for those who are still in doubt
Rags
Old Aug 12, 2008 | 11:30 AM
Ragtop's Avatar
Ragtop
The sending server has no knowledge of the receiving client. The only way this makes sense is if the forum server is mangling the mail headers. Computer-based email clients tend to be more fussy.
The sending server does have some knowledge of the receiving client,
it will have the delivery notification failures in the email logs.
It's not like it sends them out, and doesn't care if they got there or not.
Peace
Rags
Old Aug 13, 2008 | 05:48 PM
Harley.Driver's Avatar
Harley.Driver
Sorry, I'm no email expert, but I do know this is a problem on other
sites that run Vbulliten V3 or higher, the notifications get messed up in the upgrade.
When I changed my email address from outlook Pop3, to a web based email, then I got my messages, when before I wasn't.
That's the point I was trying to make in my round about way I guess.
If your gettings your messages on outlook, then maybe this is not the problem, but it seems like it fixed my problem, and it is a know issue on other sites
Rags
Same here
on my pop3 (Telenet.be) provider mail adress in Outlook = NOT
on my web-based Gmail.com adress in Outlook = OK
Old Aug 14, 2008 | 07:45 PM
TedMan's Avatar
TedMan
Default Thanks
Thanks for the fix info. Only problem is it doesn't apply to getting/resetting new passwords, as one can't login in in the first place to make the changes to the profile in HDF.
Ted
